December 25, 2025, 06:38:12 am
All Things Mk5
Mk5 General Area
URGENT oil pressure stop engine
Pages:
45
46
47
48
57
Topic: URGENT oil pressure stop engine (Read 250215 times)
doylebros
Just look at my post count
-Given: 44
-Receive: 310
Reply #675 on:
April 09, 2016, 04:34:43 pm »
Recheck it cause it will not need two?
When tightening those types of housing just a little on each bolt or the result is what you got.
Pesky jones
-Given: 2
-Receive: 19
Reply #676 on:
April 09, 2016, 05:56:17 pm »
Grr just put the hpfp back on so only got to put the pcv and battery back im done but I forgot about dinner with her family so have got to stop now. So close to finding out. I just wanna know now either way haha
callis
Always Involved
-Given: 1
-Receive: 10
Reply #677 on:
April 09, 2016, 05:58:52 pm »
TBH we all want to know and fingers crossed for you buddy :)
05 GTI 5 Door, sunroof, met paint, 18" monza, Leather Anthacite, front centre armrest, xenon headlights, Lux pack 2, Sensors, Winter Pack.
Pesky jones
-Given: 2
-Receive: 19
Reply #678 on:
April 09, 2016, 06:11:53 pm »
http://partscatalog.info/volkswagen/en/?i=cat_vag_models&brand=vw&number=1714&set=1731&ein=2008&f=625&hauptgr=1234567890&hg=1&grf=014504651&bf=14510&hgug=145&ug=45&parent_id=2852547
@doylebros
item 2 looks like it sits inbetween the cam chain cover and the vacuum pump like how ive installed it.
Also, I first thought the vacuum pump was missing a bolt when I had removed the cam chain cover, but it wasnt, the reason is because the bolt that goes there actually hold the wire loom bracket as well, so htis bolt was stored with the bracket if that makes sense
vRSAlex
Admin
-Given: 39
-Receive: 253
My Ride:
Reply #679 on:
April 09, 2016, 06:22:31 pm »
Just has one o-ring where it sits in the groove.
Looks like the vac pump is cracked too. The pressure of trying to fit another o-ring would have caused stress on it.
I have a few vac pumps here with o-ring so don't fit another.
Build Thread
www.akstuning.co.uk
- info@akstuning.com - 01234 822324
Follow AKS tuning on
Facebook
Pesky jones
-Given: 2
-Receive: 19
Reply #680 on:
April 09, 2016, 06:28:02 pm »
@vRSAlex
I have already put it back together. I only have the pcv and battery to put back on and I really want to turn it on to see if its fixed my timing problem.
Would it be ok to do this, just to log the timing, and then I wont drive it, ill buy a vacuum off you, then fit that when it arrives?
doylebros
-Given: 44
-Receive: 310
Reply #681 on:
April 09, 2016, 06:45:05 pm »
Take the extra oring out and fit the new oring in the groove where it's meant to be.
If you run it you'll suffer from oil leaks most likely but it's vacuum leaks wil cause misfire issues etc - Rather than rushing recheck all your work or you'll end up with more problems then start it.
Pesky jones
-Given: 2
-Receive: 19
Reply #682 on:
April 09, 2016, 06:50:08 pm »
Ok. Do you know the cam chain cover needs to come off to take the vacuum pump off or can I do it in situ. I think I can from memory but not looking at it right now
doylebros
-Given: 44
-Receive: 310
Reply #683 on:
April 09, 2016, 06:53:45 pm »
In situ just tricky.
Pesky jones
-Given: 2
-Receive: 19
Reply #684 on:
April 09, 2016, 07:37:43 pm »
Any tips
@doylebros
about to do it now, is it within my capabilites haha
doylebros
-Given: 44
-Receive: 310
Reply #685 on:
April 09, 2016, 07:54:33 pm »
Battery tray out and a good light, you've got the tools the last thing is patients.
When your ready for testing "Don't forget turn the engine over by hand two full turns" before going anywhere near that key.
Last Edit: April 09, 2016, 07:56:54 pm by doylebros
Pesky jones
-Given: 2
-Receive: 19
Reply #686 on:
April 09, 2016, 08:37:31 pm »
Done, rotated engine at crankshaft twice and its all good. Battery in then im firing her up?
doylebros
-Given: 44
-Receive: 310
Reply #687 on:
April 09, 2016, 08:56:46 pm »
Awaiting - watch for fuel leaks
Pesky jones
-Given: 2
-Receive: 19
Reply #688 on:
April 09, 2016, 09:00:30 pm »
Shes running nicely!!!! Been five minutes now and no horrible noises. Sounded like jow sje used to!! Wil upload a video soon. Very excited right now. About to do some logging fingers crossed
doylebros
-Given: 44
-Receive: 310
Reply #689 on:
April 09, 2016, 09:04:00 pm »
I wouldn't worry about logs get checking for oil leaks !
Pages:
45
46
47
48
57
All Things Mk5
Mk5 General Area
