Author Topic: high beam headlight not working on drivers side!  (Read 670 times)
m0rphGTD
« on: February 27, 2016, 08:39:57 pm »
nice forum you have here!.. sorry my first post is asking for help!!!
 :confused:hi, i recently bought my 04 gt-tdi it had the bulb out light on the dash when i bought it, it was late, and i assumed it was just a bulb, so bought it!
after getting sorted at home i replaced the bulb, unfortunately this has not sorted the problem.
the passenger high beam works exactly as its supposed to!
i have checked the fuses, and all is ok, stuck a multi-meter on the connector, and its only getting 1v ish.
done a wire trace and it seems to be the same up the supply wire.
i have tried replacing the ccm module, still the same.
vcds scan shows...
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 1K0 937 049 T    HW: 1K0 937 049 T*
   Component: Bordnetz-SG 1.0 H30 0704
   Revision: 00030000    Serial number: 00000000703213
   Coding: E5890F0600041800001400001400000000
   Shop #: WSC 00000 000 00000
   VCID: 408FA68B1376181ED43-8015
   Subsystem 1 - Part No: 1K2 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer VW350  012  0401
   Coding: 00065493
   Shop #: WSC 00000
   Subsystem 2 - Part No: 1K0 955 559 M  Labels: 1K0-955-559-AF.CLB
   Component: RegenLichtSens 005  0605
   Coding: 00217125
   Shop #: WSC 00000
1 Faults Found:
01499 - Bulb for High-Beams; Right (M32)
            010 - Open or Short to Plus
any help really appreciated! this is doing my head in!
