Author Topic: RCD 510 DAB - advice?  (Read 11637 times)
Offline Berry
« on: February 27, 2016, 11:57:29 pm »
Hi chaps.
I have an RCD 300 currently with an X Car Link BT which I'm looking to upgrade.
I have no real need for sat nav but am toying with the idea of (reliable) DAB and an in dash 6CD changer setup, with direct Line/aux in of some kind for music from my iphone. Not too bothered about Bluetooth connection to be honest as I've found the sound quality disappointing and don't really mind just having the phone plugged in. Also tend not to make or receive calls in the car.
Also want something OEM look. May possibly also be interested in reverse camera which I have fitted still but from the previous owners old pioneer DD head unit. As far as I'm aware it's still all wired up ready to go...
After some research I'm looking to upgrade to an rcd510 DAB 6CD.
But by the sounds of it I'll need a decent aerial, and some coding or something to stop battery drain??
Basically;
1- do you think this is the best option? And is DAB really worth the extra £££?
2- is there anyone which will properly fit inc aerial/coding etc on here? (I'm based in Surrey)
3- can you have a simple wired phone/iPod/aux connection option with this head unit?
4- would it be compatable potentially with a reversing camera?
« Last Edit: February 28, 2016, 12:34:46 am by Berry »
Shadow Blue MK5 GTI
Offline cenobytez
Re: RCD 510 DAB - advice?
« Reply #1 on: February 29, 2016, 12:50:25 pm »
1. Personally, for me. No. i have a non DAB RCD510, and have thought about it, but for the extra cost it simpy isnt justifiable in my eyes. £££ for the RCD unit, £££ for the DAB aerial.
2. cant help you there
3. I think it is easy if you want just the one option, ie ipad or USB or aux, as they all connect to the same port on the stereo, it is wanting more than once of these, the price shoots up as you would need an extra interface.
4. only certain onces with the video module would be, mine isnt. You are talking aftermarket or RNS system here.
Also, going from the RCD300 to a 510 unit you will also need a normal aeriel adaptor as the connection is different on the stereo. (a two-up connector rather than 2x connectors).
Offline white91
« Reply #2 on: February 29, 2016, 01:27:07 pm »
If you prioritise sound quality avoid the VW units
Offline Golf_GT_TDI
  • -Given: 45
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,89458.0.html
« Reply #3 on: February 29, 2016, 02:20:52 pm »
I fitted a RCD510 DAB last year, fantastic upgrade and recommend it  :happy2:
4ndy
« Reply #4 on: February 29, 2016, 02:50:00 pm »
Same here After shiny new BBS the 510DAB is my best upgrade Loads of great music Never lose signal (apart from on my own drive :stupid: :stupid:) Aerial is NOT expensive at around £60 Easy install. "dabonwheels" worth a look. I don't even use ipod usb sd that's how good it is  The 510dab can be found on ebay from reliable sellers :happy2:
« Last Edit: March 02, 2016, 06:31:44 am by 4ndy »
Offline Berry
« Reply #5 on: March 01, 2016, 09:49:59 pm »
Brilliant thanks for the advice guys.
No-one able to fit one for me? Or know someone that can??
Could try myself, I think I'd be ok with the head unit itself but how easy is the proper aerial to fit/route the cable?
Shadow Blue MK5 GTI
Offline Golf_GT_TDI
  • -Given: 45
« Reply #6 on: March 02, 2016, 12:33:19 am »
Cable and aerial fairly easy, just need to drop the rear of the headlining by removing the roof trim strip, c-pillar trims and rear grab handles, it will then drop down just enough to get access to the connectors and the large nut holding the aerial base.
I ran the cable as follows... c-pillar > left of rear seat area > under sill trims > glovebox area, taping or tie-wrapping as I went along
Offline markrtw
« Reply #7 on: March 16, 2016, 07:37:18 pm »
Something else you may need to consider (depending on your model year) is the DAB antenna.  The earlier mk5s don't have a hole in the roof for it, so I guess you would need to drill a hole for it (unless anyone knows of another reliable solution).
I'm looking into this currently and like the smooth lines of my 2005 without a roof ariel.
Offline Golf_GT_TDI
  • -Given: 45
« Reply #8 on: March 17, 2016, 09:22:21 pm »
For this you could change the hatch antenna module for the DAB version
Offline Pashka
« Reply #9 on: March 18, 2016, 12:40:55 pm »
For the DAB you can put aftermarket antenna on the windshield or plastic one - under the trim. Tested.
06 1.9 TDI Owner. Retrofits: Bixenons, Drls, Full GT/GTI exterior, RNS510+MDI+Premium Bluetooth+RVC+OPS, Full Fis, MFSW, Cruise control, TPMS, Polar Fis, Boot pop up and more.. :)
Coding, diagnostic and retrofits in Leeds
Pre coded Can Gateways for battery drain issues with RNS510 and similar headunits
Premium Bluetooth modules/kit
RNS510 Service - codes, maps/firmware updates
Latest V8 West EU maps update service for RNS315
Offline Berry
« Reply #10 on: March 18, 2016, 08:11:54 pm »
Cheers for all the comments chaps.
Have bought GarethB's old RCD 510 dab along with polo dab aerial and Bluetooth module.
Will be getting Eddie to fit next Weekend. Looking forward to hearing/seeing the upgrade.
Shadow Blue MK5 GTI
Offline Berry
« Reply #11 on: March 20, 2016, 07:59:04 am »
Quick question...
I haven't quite received the polo Dab aerial yet but assuming I will need a new long wire to go from the rcd510 to new aerial to cater for the DAB. I have a short fakra converter with 2 plugs but I take it the existing rcd300 will only have a single FM wire going to the roof, so need a dab one too?
What's best to get?
Shadow Blue MK5 GTI
Offline Golf_GT_TDI
  • -Given: 45
« Reply #12 on: March 20, 2016, 03:38:20 pm »
Quick question...
What's best to get?
I bought this one...
 http://www.ebay.co.uk/itm/Antenna-extension-cable-FAKRA-female-code-A-FAKRA-female-code-A-black-6-meter-/151579891011
Offline Berry
« Reply #13 on: March 21, 2016, 09:52:09 am »
Thanks!
Shadow Blue MK5 GTI
