Author Topic: SDHC  (Read 7528 times)
  • -Receive: 291
SDHC
« on: January 07, 2010, 12:15:53 pm »
I want to use SDHC cards with my RNS. (version B, HW11 and current firmware 1100; canbus L). Am downloading 1200 (don't like the bugs with 26xx) which in theory should have SDHC support.
Can I use any SDHC card? Are there any brands tried'n'tested by other forumites?
What is the maximum size compatible? I read that 32GB support is available only on 26xx firmware.
Re: SDHC
« Reply #1 on: January 07, 2010, 12:17:41 pm »
i thought it was only on 2660 that supported SDHC. i dont know about 1200.
I would suggest buying a quality SD card like a class 5 sandisk card. Otherwise you'll be transferring music onto it at like 1mb/second. Which will take hours for 32gb of music! and it will miss tracks!
Offline 182_blue
  • -Receive: 54
Re: SDHC
« Reply #2 on: January 07, 2010, 12:20:49 pm »
Which 26 did u have, did u try 2680 ?, some people get sdhc support on 1200, some don't, seems to be a HW thing
« Last Edit: January 07, 2010, 12:25:00 pm by 182_blue »
Offline xxx_mojo_xxx
  • MUBster DUBster
Re: SDHC
« Reply #3 on: January 07, 2010, 12:25:02 pm »
Sorry to digress a little...where can I get 2680 and what were the bugs with 2660?
  • -Receive: 291
Re: SDHC
« Reply #4 on: January 07, 2010, 12:33:12 pm »
I didn't download either 2660 or 2680. Just spent this morning reading vwnavi.
I'd always go reputable but just wondered if there were some cards that worked. Not all cards are equal and I wouldn't expect them all to work.
I was after getting class six either 16 or 32GB cards.
Offline 182_blue
  • -Receive: 54
Re: SDHC
« Reply #5 on: January 07, 2010, 12:50:41 pm »
do you have Access to VCDS and have a map on disc ?
here is 2680 http://www.megaupload.com/?d=E4ENUHO7
but only do it if you have access to vcds, ps dont bother with 2660
Offline 182_blue
  • -Receive: 54
Re: SDHC
« Reply #6 on: January 07, 2010, 12:53:20 pm »
on yours i would definitely go for 2680
Re: SDHC
« Reply #7 on: January 07, 2010, 01:10:43 pm »
im running 2660 and never had a problem. whats the beef? and whats different in 2680?
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
Re: SDHC
« Reply #8 on: January 07, 2010, 01:40:24 pm »
2660 was a beta release and 2680 is the full production version  :happy2:
Offline 182_blue
  • -Receive: 54
Re: SDHC
« Reply #9 on: January 07, 2010, 01:46:46 pm »
differences between 2680 and 2660 as posted by Mater
1. Firmware is a Factory Firmware Release version not a Beta
2. Reformats the HDD and updates the way it is addressed (hence the speed increase that is noticed by most ppl)
3. Better support for SDHC (now properly supports 32GB before some people had problems over 16GB cards)
4. Fixed Regensburg Syndrome. Will change back to your location within a couple of seconds (will depend on how good your antenna is and location but everyone who i have done the Upgrade for says it changes within about 2 secs.)
5. Fixed Battery drain issue
6. Correct support for MFSW
7. Correct support for Voice Control (it is hit an miss on 266X) It's now an option in the Setup menu & Voice Tag option is also an option when saving addresses
8. Fixed MP3 issue for HDD playback
9. Better response to touchscreen input
10. Different graphical displays for HDD capacity and copying to HDD
Re: SDHC
« Reply #10 on: January 07, 2010, 01:48:00 pm »
SOLD! to the man with the soot chucker!
Offline 182_blue
  • -Receive: 54
Re: SDHC
« Reply #11 on: January 07, 2010, 01:51:38 pm »
I have still to test mine 2680 properly but initial thoughts are good, although i have had to muve the GPS antenna to get better reception
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
Re: SDHC
« Reply #12 on: January 07, 2010, 02:15:17 pm »
After mine failed the first time to update from 2660 - 2680 (disc read error), it's now all upgraded fine but everything has been reset and text currently all in German  :laugh: :laugh:
Just need to reload the maps and updates the coding  :happy2:
Offline 182_blue
  • -Receive: 54
Re: SDHC
« Reply #13 on: January 07, 2010, 02:17:16 pm »
Steve, you my not need to reload map if your putting V6 map on, just insert the map disc for turning it back into english language and see if map is still on  as mine was still there ? :happy2:
  • MUBster DUBster
Re: SDHC
« Reply #14 on: January 07, 2010, 05:52:17 pm »
Thanks, why would I need VCDS?  I upgraded to 2660 with no issues.
P.S. Attempting to download the file comes up with a broken link!!!
