Author Topic: SDHC  (Read 7504 times)
Offline 182_blue
  • -Receive: 54
Re: SDHC
« Reply #15 on: January 07, 2010, 05:54:24 pm »
Which 26 did u have, did u try 2680 ?
Sorry to digress a little...where can I get 2680 and what were the bugs with 2660?
do you have Access to VCDS and have a map on disc ?
here is 2680 http://www.megaupload.com/?d=E4ENUHO7
but only do it if you have access to vcds, ps dont bother with 2660
Thanks, why would I need VCDS?  I upgraded to 2660 with no issues.
well, you may be ok but 2680 reverts your RNS to how it was when it left the factory, so any special bits added will be reset, like phone, reverse camera, soundpack etc etc
Offline 182_blue
  • -Receive: 54
Re: SDHC
« Reply #16 on: January 07, 2010, 05:56:31 pm »
Quote from VWnavi
Concerning the need for Coding:
The RNS510 defaults back to factory standards after upgrading with a "Factory CD". This means:
- Language will be German
- Speaker setup will be 4x 20W standard setup (no Soundsystem)
- Layout will be Highline (Silver/Black/red)
- unfortunately i do not know the default Coding for the Steering Wheel and MFD. It might cause problems with the Multifunction Steering Wheel and the Multfunction Display Plus if fitted.
As you can see from the above: The radio will work with basic settings. If you have Volkswagen Sound System or Dynaudio Sound System fitted this will not work without coding. Also it might cause pre-amp problems with the dynaudio and volkswagen sound system (not sure, just read that somewhere) if not coded right.
If you have no data on ur MFD this is a coding issue resulting from the upgrade.
If all these points work the way they did before u are fine without coding! Problem is, u will not know until you try, unless u can say: i have no soundsystem installed, my skin is highline and my MFD doesnt support the RNS anyway...
Offline xxx_mojo_xxx
  • MUBster DUBster
Re: SDHC
« Reply #17 on: January 07, 2010, 05:56:54 pm »
Can I not go to the dealership and ask them to do the upgrade, i.e. if I complain about speed of satnav, etc.?
Offline 182_blue
  • -Receive: 54
Re: SDHC
« Reply #18 on: January 07, 2010, 05:58:38 pm »
you could try, it might be like asking the government to reduce the duty on fuel by half though  :P, on a serious note was your Nav in the car from new ?
« Last Edit: January 07, 2010, 06:19:38 pm by 182_blue »
  • MUBster DUBster
Re: SDHC
« Reply #19 on: January 07, 2010, 07:56:50 pm »
Yes, RNS510 (the touch screen version) was in my car from factory.
Offline 182_blue
  • -Receive: 54
Re: SDHC
« Reply #20 on: January 07, 2010, 08:01:21 pm »
In that case they may do the upgrade if you say you have issues , tell them your friend had same issues and the dealer put new firmware on that fixed it  :happy2:
Offline winrya
Re: SDHC
« Reply #21 on: January 11, 2010, 04:53:59 pm »
differences between 2680 and 2660 as posted by Mater
1. Firmware is a Factory Firmware Release version not a Beta
2. Reformats the HDD and updates the way it is addressed (hence the speed increase that is noticed by most ppl)
3. Better support for SDHC (now properly supports 32GB before some people had problems over 16GB cards)
4. Fixed Regensburg Syndrome. Will change back to your location within a couple of seconds (will depend on how good your antenna is and location but everyone who i have done the Upgrade for says it changes within about 2 secs.)
5. Fixed Battery drain issue
6. Correct support for MFSW
7. Correct support for Voice Control (it is hit an miss on 266X) It's now an option in the Setup menu & Voice Tag option is also an option when saving addresses
8. Fixed MP3 issue for HDD playback
9. Better response to touchscreen input
10. Different graphical displays for HDD capacity and copying to HDD
Does the battery drain fix mean earlier cars no longer need the updated can bus?
Offline mortygttdi
  • -Receive: 146
Re: SDHC
« Reply #22 on: January 11, 2010, 05:05:45 pm »
possibly but if you dont update the can bus the you will get coms errors with the gateway and nav/radio.
Darren :happy2:
Offline winrya
Re: SDHC
« Reply #23 on: January 11, 2010, 05:27:27 pm »
Cheers, mine works so gonna leave it that way!
Well apart from a dodgy volume control lol, anyone else had any issues??
  • MUBster DUBster
Re: SDHC
« Reply #24 on: January 11, 2010, 05:34:22 pm »
Darren :happy2:
How do I check if I have the updated CAN bus?
Offline 182_blue
  • -Receive: 54
Re: SDHC
« Reply #25 on: January 11, 2010, 06:33:41 pm »
Darren :happy2:
VCDS  :happy2:
Re: SDHC
« Reply #26 on: January 11, 2010, 06:35:20 pm »
shaun where did you get your custom POI's for speed cameras etc? any body got an up to date disc? did i see a pic from morty with Vpower on too? any help guys? ive currently got V6 map on the DL
Offline 182_blue
  • -Receive: 54
Re: SDHC
« Reply #27 on: January 11, 2010, 06:45:50 pm »
Steve p helped me with mine  :wink:
Offline mortygttdi
  • -Receive: 146
Re: SDHC
« Reply #28 on: January 11, 2010, 07:09:46 pm »
I was gonna give you one the other day Jay whoooo her misses :grin:  I forgot to leave a disc out.
I can put what ever poi you want on a disc,
Just hoping V7 comes quiet soon cos V6 is just a bug fix.
Darren
Re: SDHC
« Reply #29 on: January 11, 2010, 07:10:50 pm »
Darren
ah is it too big to upload? no worries mate, i think ive got V4 maps so it would be a good move for me and v6. cheers pal
