Author Topic: Clunk noise from my car when pressing clutch at low speeds  (Read 1890 times)
Offline yousafzafar
« on: February 28, 2016, 12:11:36 pm »
Hey guys,
I don't know if this has been asked already so please excuse me if it has, but I have a Mk5 R32 6 Speed Manual and recently I have noticed that whenever I am in slow moving traffic (which thankfully I am in every day because I live in London, yay..) and I put my clutch down just before coming to a stop, my car clunks very weirdly, it feels as though it's been forced out of gear or something. Has this happened to anyone and would anyone know exactly what this could be? Thanks guys
Offline MS1
Re: Clunk noise from my car when pressing clutch at low speeds
« Reply #1 on: February 28, 2016, 12:35:56 pm »
Could be the flywheel re engaging (if it's got one)  and as it's got more worn, the side to side play has become more excessive. I had mine like this on a GTI for 20,000 miles before I bit the bullet and bought a new clutch and dmf.
R-Tech Map/ Longlife TBE w/200 cell Sports Cat / ITG Maxogen G60 / Loba HPFP / Forge Twin FMIC / Forge TB Hose / R8 Coilpacks / Neuspeed Power Pulley / EBC D&G Front & Rear Discs / EBC Yellowstuff Pads / BSH PCV Kit / Super-Pro Front & Rear / W.A.L.K / APR Torque Arm / 034Motorsport Density Line Engine Mounts / Vibratechnics Subframe Mount / Vibratechnics Dogbone Bush
284bhp / 307lbft
Offline FJ1000
  • -Receive: 48
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,101205.0.html
« Reply #2 on: February 28, 2016, 01:26:59 pm »
Has it ever had a new clutch fitted?
I had something similar on my Audi (like a shunting sensation) and it turned out the subframe bolts had not been properly torqued up by AMD after they fitted a new clutch.
2007 Golf Gti DSG | Leather Wingbacks | Xenons | VWR Springs | Tinted Windows | 18" Audi Speedlines |
Offline yousafzafar
« Reply #3 on: February 29, 2016, 01:43:02 am »
I'm not too sure to be honest, I guess I will just have to take her to the garage and hope for the best.
Thanks for the help guys!
Offline MS1
« Reply #4 on: February 29, 2016, 06:59:01 am »
No problem mate.
Riding the clutch, even minimally, which is almost inevitable in slow moving traffic, may well point towards an excessively worn clutch plate or Flywheel and the difficulty either of them may be having trying to re-engage, but any mechanical will tell you to continue as you are until the clutch starts slipping or goes completely.
The subframe bolts having loosened off is also a possibility, but usually it's only identifiable in left to right turns or vice versa. I've never heard of it on clutch release or coming to a stop.
Another thing it may be is an engine or transmission  mount, some times the rubber bushes get worn and the play becomes excessive causing the metal to knock. What you're describing could easily be that.
What I would say is, don't think worse case scenario, because it probably isn't. We all do it, but it's usually always unjustified.
284bhp / 307lbft
