Author Topic: Manual GTI - 1st Gear Notchy/Differcult to engage.  (Read 2298 times)
Offline daz_rt_04
« on: February 28, 2016, 05:14:57 pm »
Hi guys,
New to VAG ownership and have encountered my 1st issue with my Mk5 Gti.
Basically all gears inc reverse are smooth in action but 1st gear can be differcult to get into, from either cold or hot and from neutral up or 2nd down.. its still awkward.
This can usually be rectified with a bit of a shove or double clutching but its bloody annoying.
Clutch is smooth and has a good level of bite. Am I correct in thinking it may be the linkages? Adjustment?
Cheers in advance.
Kiukas
Re: Manual GTI - 1st Gear Notchy/Differcult to engage.
« Reply #1 on: February 28, 2016, 08:48:27 pm »
Check dieselgeeks video,
« Last Edit: February 28, 2016, 08:56:45 pm by Tfsi_Mike »
« Reply #2 on: February 28, 2016, 08:57:15 pm »
Fixed the link for you   :happy2:
Offline MS1
« Reply #3 on: February 28, 2016, 09:04:46 pm »
Mine was the same. Charged the gearbox oil, with genuine VAG gear. Problem solved. Silky smooth.
R-Tech Map/ Longlife TBE w/200 cell Sports Cat / ITG Maxogen G60 / Loba HPFP / Forge Twin FMIC / Forge TB Hose / R8 Coilpacks / Neuspeed Power Pulley / EBC D&G Front & Rear Discs / EBC Yellowstuff Pads / BSH PCV Kit / Super-Pro Front & Rear / W.A.L.K / APR Torque Arm / 034Motorsport Density Line Engine Mounts / Vibratechnics Subframe Mount / Vibratechnics Dogbone Bush
284bhp / 307lbft
Kiukas
« Reply #4 on: February 28, 2016, 09:09:10 pm »
Cheers Mike :happy2:
Offline daz_rt_04
« Reply #5 on: February 28, 2016, 11:25:04 pm »
Thanks for the replies chaps.
Its quite strange as if I push the lever further over than you normally would, it slots into 1st fine.
Will follow the video and see how it goes!  :drinking:
