Author Topic: 2005 gti and rcd510  (Read 6006 times)
Offline Reecey
2005 gti and rcd510
« on: March 01, 2016, 09:40:18 pm »
looking to change my bog standard unit for a rcd 510 but seems abit of a mine field, have tried searching for the details on fitting one to this age car but found nothing really in one place with the answers i need! could someone help me on what i need to buy or what i need to check before buying and fitting one?
thanks
05 Gti
Lowered
Bluefin Stage 2
Offline cenobytez
Re: 2005 gti and rcd510
« Reply #1 on: March 02, 2016, 01:04:51 pm »
with having an early mk5, fitting one would give you battery drain problems, so you would need to update/upgrade your canbus. The only other thing you will need is an aerial adaptor, your original has 2x seperate connectors, but the RCD510 has a single twin connector, you can either buy the adaptor cable, or customise your existing connector so it will fit.
Other than these it is a straight fit.
Offline Reecey
« Reply #2 on: March 02, 2016, 08:11:03 pm »
is it easy to replace the canbus?? or how would i go about upgrading it?? is it otherwise plug and play? the plugs the same? is the adaptor readily available?
05 Gti
Lowered
Bluefin Stage 2
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #3 on: March 02, 2016, 08:35:57 pm »
You gather the details off your old canbus on vcds, remove old one, put new one in and  program the new one according to the info from old canbus..no need for adapters.
It can be a pain to take it out though. Especially in a manual car as clutch is in the way
Sent from my SM-G928F using Tapatalk
Offline Reecey
« Reply #4 on: March 02, 2016, 09:53:52 pm »
sounds like a ball ache! is there any known guides for this?
05 Gti
Lowered
Bluefin Stage 2
Offline loop
  • -Given: 26
« Reply #5 on: March 03, 2016, 02:17:18 am »
You could employ the services of EddieNL from this forum who could do all this for you for a reasonable price.
‘05 GT, Retrofits: RNS 510 DAB+, R32 Highline Cluster, R32 MFSW, Mk6 Reversing Camera, 7P6 Bluetooth, TPMS, Cruise Control, VW MDI, Chrome switches, Blaupunkt THA 475 amp.
Offline Bigjimknickers
  • -Given: 55
« Reply #6 on: March 03, 2016, 06:54:28 am »
Or..
Look at the Dynavin N6 VW
Or the blaupunkt 835
Both are high quality plug & play without the ball ache- (currently saving for a N6 after trying various units & being disappointed.
Offline Pashka
« Reply #7 on: March 03, 2016, 11:46:17 am »
I can supply you precoded can gateway, straight plug and play thing. Also, can fit if you are near Leeds.
06 1.9 TDI Owner. Retrofits: Bixenons, Drls, Full GT/GTI exterior, RNS510+MDI+Premium Bluetooth+RVC+OPS, Full Fis, MFSW, Cruise control, TPMS, Polar Fis, Boot pop up and more.. :)
Coding, diagnostic and retrofits in Leeds
Pre coded Can Gateways for battery drain issues with RNS510 and similar headunits
Premium Bluetooth modules/kit
RNS510 Service - codes, maps/firmware updates
Latest V8 West EU maps update service for RNS315
Offline Reecey
« Reply #8 on: March 03, 2016, 07:34:34 pm »
how much would we be talking supplied??
05 Gti
Lowered
Bluefin Stage 2
Offline Pashka
« Reply #9 on: March 03, 2016, 08:26:13 pm »
45 coded and delivered  :happy2:
Offline glasgowdubber
« Reply #10 on: March 04, 2016, 10:28:30 am »
Sorry to jump in on this, so if I were to use a pre-coded canbus on an 05, I can fit an RS510?
« Last Edit: March 04, 2016, 01:24:43 pm by glasgowdubber »
Offline Lyons
  • -Given: 18
« Reply #11 on: March 04, 2016, 01:11:21 pm »
Yes.
Offline Robna
« Reply #12 on: March 05, 2016, 01:14:06 pm »
Is there a cutoff point for needing the updated canbus? My car is a 57 plate GTI and I am considering fitting an RCD510 (non DAB) and an Aux/USB.
Thanks for the help. And sorry to jump on your thread  :happy2:
4ndy
« Reply #13 on: March 05, 2016, 02:25:02 pm »
Should be OK. My 07 is fitted with rcd510 DAB ,no battery drain. Sure the part number of the gateway ends with a K or later  Sure someone can clarify this for you :happy2:
Offline Robna
« Reply #14 on: March 05, 2016, 03:15:43 pm »
Brilliant. Cheers for that, I will wait and hear from the experts  :drinking:
Is there a difference in the units that I see on eBay that are from Chinese sellers as opposed to uk versions?
