Author Topic: Eibach 30mm vs H&R 35mm - pic request  (Read 9158 times)
Offline Vwgtiking
« on: March 02, 2016, 01:00:59 pm »
Any one got pics of either of these on their cars? Looking at there stance. Pls
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
Re: Eibach 30mm vs H&R 35mm - pic request
« Reply #1 on: March 02, 2016, 01:35:48 pm »
GTIs only have one part reference for H&R -30 mm springs.
Eibach sells Pro-Kits (will only lower around 10-15 mm) and Sportlines (will lower around 30 mm). The Sportlines are very similar to H&R -30 mm, but you'll notice the rear a bit higher than the front, compared with H&R springs. :wink:
You can see pictures from Sportlines (initial pictures) and from H&R -30 mm (last pictures) in my Ed. 30 project.
I have Eibach Pro-Kits in my GT Sport. It rides much higher.
Offline FJ1000
  • -Receive: 48
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,101205.0.html
« Reply #2 on: March 02, 2016, 04:28:22 pm »
Don't forget the VWR springs, similar drop to the 2 mentioned and still give a ride close to OEM.
I'm sure there are loads of pics of all 3 setups if you have a search...
2007 Golf Gti DSG | Leather Wingbacks | Xenons | VWR Springs | Tinted Windows | 18" Audi Speedlines |
Offline Vwgtiking
« Reply #3 on: March 02, 2016, 04:36:11 pm »
So the H&Rs will sit better
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #4 on: March 02, 2016, 05:07:16 pm »
Ive got sportlines on mine,  2 people in the last week who had h&r's 30mm from this forum said that my sportlines look a little lower at the front.
But i agree that h&r are lower at the back which give the car an equal lower look . eibachs are a little high on the rear
Sent from my SM-G928F using Tapatalk
« Last Edit: March 02, 2016, 05:09:49 pm by RetroRaz »
Offline StuF
  • -Given: 31
  • -Receive: 38
« Reply #5 on: March 02, 2016, 05:12:10 pm »
I defy anyone to actually tell the difference between H&R springs vs Eibach without knowing what is actually fitted
Both are a good choice as good as each other and provide the same drop and stance
Peeps with Eibach say go for Eibach and peeps with H&R say H&R - either or in my opinion
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #6 on: March 02, 2016, 05:16:35 pm »
I had Eibachs Sportlines and changed to H&R -30 mm. I think I can tell the difference easily. The stance is a bit different. :wink:
For me H&R suit better my Koni Sport dampers, hence the change. I love how my Ed. 30 rides now with the handling upgrades I've done to it. :smiley:
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #7 on: March 02, 2016, 05:41:37 pm »
Just to add i have eibachs sportline on standard tdi shocks,  drove a gti with sportlines and it was a bit harsher. Probably because of different shocks that's why
Offline bbfb10
« Reply #8 on: March 02, 2016, 06:25:53 pm »
Im on Eibach Sportlines. Check my build thread for pics.
Full VCDS Hex + Can.
Offline Vwgtiking
« Reply #9 on: March 02, 2016, 06:32:28 pm »
Any pics mate as I have a tdi.
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #10 on: March 02, 2016, 06:32:45 pm »
Should be some in my build thread
Offline Vwgtiking
« Reply #11 on: March 02, 2016, 06:32:57 pm »
Can I have direct link including page number.
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #12 on: March 02, 2016, 06:46:21 pm »
http://www.mk5golfgti.co.uk/forum/index.php/topic,90564.135.html
Post 148 and 151
Offline Vwgtiking
« Reply #13 on: March 02, 2016, 07:36:25 pm »
That looks spot on. What car do you exactly. I have a Jetta bkd so hoping for similar drop. Are they the 30mm pro? I can't find sportlines with just 30mm drop.
« Last Edit: March 02, 2016, 07:40:13 pm by Vwgtiking »
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #14 on: March 02, 2016, 07:56:21 pm »
So its a golf tdi sport which is 15mm lower  from the factory than standard tdi height.
The eibachs sportlines are 40-45mm lower than standard so they are 30mm lower than sport height.
I think i have a bkc engine. Its a dsg so a bit heavier at the front too.
