Author Topic: Spark Plug Choice  (Read 4991 times)
Offline Gman30
  • Mk1 GTI to a MK5 GTI Edition 30
Spark Plug Choice
« on: March 05, 2016, 11:35:20 am »
Sorry I know plugs must have been covered a million times but...
Ok so my standard Edition 30 is going in for it's full annual service this week. I have always fitted the standard NGK Platinum plugs and had no issue's tbh!!
Just wondering if people recommend upgrading to the Iridium plug for a stock car? Also I am confused by the NGK part numbers/variations.
so the NGK plug finder site state's:
The standard plug is the:
PFR7S8EG-1675 - What I usually fit (OEM)
Iridium version is the:
IFR7X8G - 95820
Looking at the Awesome GTI site and other places including threads on this forum the more common Iridium plug is the:
NGK BKR7EIX
So what is the difference and are the Iridium version/s better on a stock car?
Thanks in Advance!!   :laugh:
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Re: Spark Plug Choice
« Reply #1 on: March 05, 2016, 03:15:12 pm »
NGK BKR7EIX Iridium plugs.
Ebay are cheaper a lot cheaper as I bought a set. :happy2:
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
« Reply #2 on: March 06, 2016, 07:31:44 am »
Use oem, or BKR7EIX, unless you have had bad experiences with them. Most of the time they work best. If you had a bunch of upgrades and tune with a very aggressive tune and much higher boost...I would suggest NGK PFR7B...they come with a 0.7mm (0.028") gap: http://www.hstuning.com/product_info.php?cPath=24_32&products_id=3688&vpath=30_31
« Last Edit: January 30, 2021, 04:28:58 am by ROH ECHT »
Offline Eddy588
  • Newbie
« Reply #3 on: January 23, 2021, 09:36:42 pm »
Use oem unless you have had bad experiences with them. Most of the time they work best. If you had a bunch of upgrades and tune with a very aggressive tune...I would suggest NGK PFR7B at 0.028" gap: http://www.hstuning.com/product_info.php?cPath=24_32&products_id=3688&vpath=30_31
Just want to thank you fitted these plugs today on my stage one Edition 30 with ko4 and they really work well.
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
« Reply #4 on: January 30, 2021, 04:25:05 am »
You are welcome. Happy to hear it. They work great with the 3.3 M Ohm OE coils and they can handle high boost pressure should you go for more. They worked great with my K04 tuned to boost 26 to 28 psi. Never again had an issue once I switched to the NGK PFR7Bs.
« Last Edit: January 30, 2021, 03:55:43 pm by ROH ECHT »
  • -Receive: 692
« Reply #5 on: February 05, 2021, 07:40:38 pm »
They look like OEM double platinum (platinum tip + platinum ground pad) plugs to me?
I don't know why there's such a big thing about plugs in the US with gapping etc.  Over here we just take them out of the packet and shove them in the engine, with zero misfiring problems.  Even the OEM dealer supplied double platinum plugs are fine with Stage 2+ KO4s, out of the packet.  But the plug of choice here is the BKR7EIX.  Cheap and works well.
Offline GVK
  • -Receive: 76
    • GVKmotorsport
« Reply #6 on: February 05, 2021, 08:49:36 pm »
I used these in mine,been  fine for over 2 years so far NGK PFR7S8EG-1675
Offline DBXdarkangel
  • -Given: 18
« Reply #7 on: February 05, 2021, 10:32:55 pm »
Agreed. Exactly what's in mine.
