Author Topic: edition 30 owners with ttrs brake setup  (Read 9982 times)
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=00i6v4oni3v6q8ha7m6fqb7qb3&/topic,19740.0.html
Re: edition 30 owners with ttrs brake setup
« Reply #15 on: March 08, 2016, 10:54:35 am »
Ttrs + 2piece 362mm discs. Req. 8mm spacer
  • -Receive: 427
« Reply #16 on: March 08, 2016, 10:57:59 am »
Ive NQSBBK on mine behind the VZ's (exat same design/look as your Pescarsas)..........
As mentioned, Alex does the whole TTRS kit......
http://www.akstuning.co.uk/vagbremtechnic/148-vagbremtechnic-rs3-362mm-disc-upgrade-kit.html
Offline xjay1337
  • -Receive: 377
« Reply #17 on: March 08, 2016, 11:14:41 am »
Should also say it's £1200 with the TTS setup.
Offline AJP
  • -Given: 392
  • -Receive: 316
« Reply #18 on: March 08, 2016, 11:20:16 am »
Those discs are a bit serious! Could do with a kit with 340s.
Offline AJP
  • -Given: 392
  • -Receive: 316
« Reply #19 on: March 08, 2016, 06:16:29 pm »
I missed that. Ta for the info mate.
Offline Markyvitch
« Reply #20 on: March 09, 2016, 09:36:26 am »
Ttrs fitted all round 12mm spacers all round and remove the screw on the front arch on mine lowered 30mm, but would prefer not to run spacers :thinking:
Offline oak_grun
« Reply #21 on: March 09, 2016, 09:57:43 am »
May have ever located a set of  nqsbbk calipers.
They are off a 986 boxster..2000 model. ..can anyone confirm they are correct ones as per nqsbbk.
  • -Receive: 427
« Reply #22 on: March 09, 2016, 01:55:48 pm »
Check the part numbers. The NQSBBK Calipers are from the Porsche Boxster 2.5 & 2.7.
Taken from DaveB's original thread....
The part numbers you need are 986 351 421 & 422
Just a brief explanation of part numbers:
First three are the model number 986=Boxster, 996=911, 955=Cayenne
351 = Front brakes
421 Left Caliper (odd numbers) & 422 Right Caliper (Even numbers)
Dont buy anything with a 352 in the part number they are rear calipers and the pistons are too small for a Mk5
Offline oak_grun
« Reply #23 on: March 09, 2016, 04:56:45 pm »
351 = Front brakes
Legend! Thanks MC71...they turned out to be rear calipers...
The search continues.....
  • -Receive: 427
« Reply #24 on: March 09, 2016, 06:56:14 pm »
If you don't find anything soon (ish) my complete NQSBBK kit will be for sale in the next few months If i don't sell my car as she is (modified) as I will be having here returned to standard and all parts taken off.
Offline oak_grun
« Reply #25 on: March 09, 2016, 07:19:02 pm »
1st first dibs if u do decide to return her to standard.
Good luck with the sale!!
Offline A10myr
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,109437.0.html#new
« Reply #26 on: March 09, 2016, 07:22:54 pm »
i originally was going to go for the ttrs brake setup until someone told me i have to change the master cylinder  :fighting:
  • -Receive: 427
« Reply #27 on: March 09, 2016, 07:25:13 pm »
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #28 on: March 09, 2016, 07:27:07 pm »
Not true. I have the 6 pot Brembo 18Z and rear R32 brake setup with the factory fitted master cylinder and great pedal feel and travel. Already tested the setup on track. Amazing braking power that I won't use on the road unless on an emergency braking.
The TTRS calipers are a good match for the GTI master cylinder. :wink:
Offline AJP
  • -Given: 392
  • -Receive: 316
« Reply #29 on: March 09, 2016, 07:41:39 pm »
There were two different master cylinders fitted to the GTI though weren't there?
One with 22 in the part number, one with 23.
We want the one with 23. I'm sure it was you that told me this!
