Author Topic: lower dash help  (Read 1057 times)
Offline kierhanlon6
lower dash help
« on: March 08, 2016, 08:54:54 pm »
hello i have a vw phone prep kit fitted to my mk5 golf passenger side. worried when i remove it will be a big hole so after a replacement lower dash has any one done this and is it easy?
Offline ady-uk
  • -Given: 19
  • -Receive: 24
Re: lower dash help
« Reply #1 on: March 09, 2016, 08:13:35 am »
There will be a big hole, two small, but ugly, screw holes too.
I bought a new glove box trim, cost about £50 new.
There is also the phone kit controller, hidden under the drivers seat, buried in the side
It's a grey long box with plugs each end, you need to disconnect this or you'll never be able to fit the current bluetooth kits.
It'll keep causing problems and causing conflicts :(
VW Golf 2.0 Gtd 140 4motion (2005)
Factory fitted: xenons, sunroof, heated leather seats, fold in mirrors with downlights,
Custom: Mk6 steering wheel, updated gateway, RNS510 remote boot pop, LED lighting.
Offline kierhanlon6
Re: lower dash help
« Reply #2 on: March 09, 2016, 08:24:05 pm »
 :P
brilliant thanks for your help. where did you buy yours from don't suppose you no the part number do u? ok just un plug from the grey box no where else?
thanks again
Offline ady-uk
  • -Given: 19
  • -Receive: 24
Re: lower dash help
« Reply #3 on: March 10, 2016, 08:06:04 am »
Bought mine from VW dealer, but I'd ring TPS and ask them, as I get most stuff, direct from them now :)
Don't need to know part, Just give them reg No. and tell them its lower dash that glove box fits into.
They will look it up on computer.
You can transver the actual glove box, plastic hinge pins, trim etc, over a quiet few hours :)
