Author Topic: Vag Commander 1.4  (Read 4074 times)
Offline white91
Vag Commander 1.4
« on: March 10, 2016, 10:16:04 am »
Bought VC 1.4, but I've no idea how to install it, the instructions keep referring to some kind of dongle?
Anybody else struggled to install vag commander?
Should I return it and buy a later version?
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
Re: Vag Commander 1.4
« Reply #1 on: March 10, 2016, 10:37:06 am »
What are you trying to do with it? You know that on the later Mk5 Golfs its next to useless and cannot be used for things such as key coding, clock changes etc. yeah?
Offline white91
« Reply #2 on: March 10, 2016, 11:04:42 am »
Retrieve my code to swap to highline clocks.
2005 car 972 clocks
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #3 on: March 10, 2016, 11:40:05 am »
Have you run vag commander as admin?
Sent from my SM-G928F using Tapatalk
Offline skard
  • -Receive: 245
« Reply #4 on: March 10, 2016, 11:42:19 am »
You need the drivers installed for the lead, serial to USB. Look in your device manager if it needs attention. Are they not on the CD? May have to manually install them.
And the cable should be plugged in before running the software.
If you get in, a word of  advice, don't go crazy snooping about other modules as it isn't a good setup for that. Just try grab your SKC and get a dump of your IMMO.
Offline white91
« Reply #5 on: March 10, 2016, 12:36:01 pm »
All I want to do is get my SKC and that's it, don't want to cause myself any problems!
As its a mini cd I've had to copy onto usb stick and load from that.
I can't even get the software to install let alone find drivers for the cable?
Shall I screen shot the files I have on usb stick?
Offline skard
  • -Receive: 245
« Reply #6 on: March 10, 2016, 01:16:22 pm »
Your antivirus has probably killed the executable file.
You need to turn it off, then copy it again. Should be a program called vwtester perhaps.
If asking for a dongle then the drivers are probably still needing installed.
