Author Topic: R-Tech Full PCV Delete  (Read 11247 times)
Offline Andyrtech
  • Hagrid
  • Trader
  • www.r-techdevelopment.co.uk
    • http://www.r-techdevelopment.co.uk
« on: March 10, 2016, 05:05:17 pm »
This is a kit to blank the oem pcv system to stop the crank and cam gasses being vented back into the combustion chamber via the turbo or manifold. This kit gives the user the option to fully vent the crank and cam gases individually to dramatically reduced the crank pressure build up, the gasses can be vented to atmosphere or you can use a catch can if you wish.
full version kit consists of the alloy cam cover blank plate which still allows cam gas movement within the cam cover – turbo intake blank plate – inlet manifold blank plug which can also be used as a boost gauge or wmi tap – 22mmm crank hose and 25mm cam hose with clips.
Other solutions on the market still combine the crank and cam gasses into one feed back into the turbo, some will have a catch can in-line but they still allow the oil vapours back to the turbo and are prone to build up of crank case pressure causing a moment of white tail pipe smoke on idle or between gear change. The only reason for this kit is to fill a well needed void in the tfsi modding market.
These retail at £120 + Free Shipping
        TEL: 07708055147
