Author Topic: Retro fit front fogs  (Read 3621 times)
Offline Vwgtiking
« on: March 11, 2016, 06:15:53 pm »
I have Jetta. The previous owner had front fogs install and has a switch in the ash tray to turn it off and on. Is there anyway that I wire the +ve wire through the existing rear fog switch behind the light switch. Or if I purchase another light switch that has the front fog option I can wire it up? I prefer the latter option.
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
Re: Retro fit front fogs
« Reply #1 on: March 11, 2016, 08:05:34 pm »
You can get a new switch and run a wire from the switch to the cecm and then 2 wires from the fogs to the cecm and ground them and just  code them in.
Or if you dont want ro run to cecm, there is a method where you can use a relay but not sure how that's wired.
Ive done 2 fog retrofits using the cecm method and you will need a highline cecm module
Sent from my SM-G928F using Tapatalk
Offline Vwgtiking
« Reply #2 on: March 11, 2016, 11:48:06 pm »
Oh can I not just have a +ve in with a +ve out creating a switch with the light switch??
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #3 on: March 12, 2016, 10:48:16 am »
Yeah that would be the relay method of wiring it but you would need a new light switch
Offline Vwgtiking
« Reply #4 on: March 13, 2016, 11:25:50 pm »
Looks simple enough. 2 questions. Which relay do I need? And where do I get a relevant trigger wire that will fit in the light switch plug?
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
Offline stuart-88
  • -Receive: 21
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,101197.0.html
« Reply #6 on: March 22, 2016, 10:57:22 pm »
I made a fog light loom for another guy on the forum a while back. He never bothered having it in the end. If you want it let me know, it's gathering dust some where at the moment.
Instagram: stu_nc88
Offline Vwgtiking
« Reply #7 on: April 11, 2016, 05:26:49 pm »
Hi mate. Any pics? What does the loom consist of?
Offline stuart-88
  • -Receive: 21
« Reply #8 on: April 11, 2016, 06:40:25 pm »
I'll try get some pictures Wednesday. Consists of relay, relay holder with fuse, necessary wires, 12v power, pick up point from the fog light (you'll need a headlight switch with fog light attachment) earth and the leads to run to the front fogs. All wired ready to go.
Also requires a trigger/repair wire which you can pick up from the dealers for a couple of £. Part number 000979009  :happy2:
« Last Edit: April 11, 2016, 06:44:12 pm by stuart-88 »
Instagram: stu_nc88
Offline Vwgtiking
« Reply #9 on: April 11, 2016, 06:55:01 pm »
Do the wires have the plugs to go into the bulb holders?
Offline stuart-88
  • -Receive: 21
« Reply #10 on: April 11, 2016, 06:57:54 pm »
No they don't. I can't remember the bulbs type either but pretty sure I just bought some connectors for it from ebay
Instagram: stu_nc88
