Author Topic: Cam adjuster rattle  (Read 1185 times)
Offline Andrew
Cam adjuster rattle
« on: March 11, 2016, 06:16:32 pm »
Managed to get the horrid adjuster rattle once the engine is up to temp again, can only assume due to poor fitment or a faulty part. It is more of an annoyance as it only comes now and again and doesn't affect the drive, so I'm wondering what is actually going on when it rattles? Is anything going to catastrophically go wrong or will it be fine to put up with (until I can stump up the £300 for the part plus labour :( )
Offline MS1
Re: Cam adjuster rattle
« Reply #1 on: March 11, 2016, 08:49:38 pm »
No idea mate, but I've had the rattle for 30k and it's never caused a problem.
R-Tech Map/ Longlife TBE w/200 cell Sports Cat / ITG Maxogen G60 / Loba HPFP / Forge Twin FMIC / Forge TB Hose / R8 Coilpacks / Neuspeed Power Pulley / EBC D&G Front & Rear Discs / EBC Yellowstuff Pads / BSH PCV Kit / Super-Pro Front & Rear / W.A.L.K / APR Torque Arm / 034Motorsport Density Line Engine Mounts / Vibratechnics Subframe Mount / Vibratechnics Dogbone Bush
284bhp / 307lbft
