Author Topic: Aftermarket head unit and ECU issues  (Read 2380 times)
Offline GTS_1985
« on: March 14, 2016, 10:07:24 am »
Hi all,
Newbie here so apologies if it has been covered but I can't find it anywhere.
I have a mark 5 gti that current has a stage 1 remap installed. I have since looked into replacing the stock head unit with a satnav touch screen unit but have been told by a sales rep at a tuning firm that it will mess with the remap when I try to install it! So am I stuck with the oem unit as I don't want to mess up the remap.
Sent from my SM-G935F using Tapatalk
Offline Pashka
Re: Aftermarket head unit and ECU issues
« Reply #1 on: March 15, 2016, 11:06:35 am »
bullsh1t. Ecu and headunit are two different systems.
06 1.9 TDI Owner. Retrofits: Bixenons, Drls, Full GT/GTI exterior, RNS510+MDI+Premium Bluetooth+RVC+OPS, Full Fis, MFSW, Cruise control, TPMS, Polar Fis, Boot pop up and more.. :)
Coding, diagnostic and retrofits in Leeds
Pre coded Can Gateways for battery drain issues with RNS510 and similar headunits
Premium Bluetooth modules/kit
RNS510 Service - codes, maps/firmware updates
Latest V8 West EU maps update service for RNS315
Offline theminty1
« Reply #2 on: March 16, 2016, 11:22:33 am »
Correct he be talking poo.
Disconnect the battery before starting and you are safe
140 BKD GT TDi  5dr
Offline GTS_1985
« Reply #3 on: March 16, 2016, 11:50:11 am »
I thought it was a weird thing to say, but can't see why he'd bullsh1t! So fitting a DAB will all be sound? Wouldn't I have to recode things?
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #4 on: March 16, 2016, 05:16:46 pm »
The new headunit won't mess your ECU map. At worst you'll need to update the CAN Gateway or buy a Polar BT/Battery module to prevent battery drain from newer generation radios. Any 2008 and late 2007 Golf should be fully compatible with the new radios. You'll need to code the radio if it came from a car with a different sound system from yours.
Offline Pashka
« Reply #5 on: March 16, 2016, 06:50:16 pm »
I know that aftermarket radios put 12v to different pin on the OBD socket and diagnostic tool, for example VCDS, can burn, but this one heard first time  :signLOL:
