Author Topic: Depo xenon headlights  (Read 8045 times)
Offline Danknott15
« on: March 17, 2016, 07:41:58 am »
Morning just about to purchase the depo xenon headlights but just wanted a bit of advice. Do I need to purchase a canbus H7 HID kit for the main beam or is non canbus ok? Also do I need any additional adapters or bulb holders etc?
Thanks in advance
Offline akbarirfan
  • -Given: 81
Re: Depo xenon headlights
« Reply #1 on: March 19, 2016, 11:55:49 pm »
No additional adapters needed.
I went for a canbus kit but have feeling that it is not required - I did have to code the xenons so that they both worked though.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #2 on: March 20, 2016, 12:03:42 am »
Hi, I have a pair of these and the canbus kit is not required so you'll be fine with a standard hid bulb kit.
Offline Danknott15
« Reply #3 on: March 20, 2016, 09:42:05 am »
Cheers for the help guys. What coding needs doing?
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #4 on: March 20, 2016, 10:38:03 am »
Tick box in cecm module that says xenon installed without shutters
Sent from my SM-G928F using Tapatalk
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #5 on: March 20, 2016, 03:37:37 pm »
As RetroRaz says tick xenons installed without shutters.
Offline An0NyMOUs
  • A Nuisance
« Reply #6 on: March 20, 2016, 06:09:36 pm »
Are HID's in the main beam a good idea? They aren't a great idea for flashing people as they won't warm up quick enough
2.0 FSI 4motion
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #7 on: March 20, 2016, 08:17:25 pm »
Not a good idea. Better off getting genuine ones and running shutter wires which open and close when flashing
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #8 on: March 20, 2016, 08:22:59 pm »
There's a set on the forsale section for £450 but I couldn't afford those so went for the cheap ones  :doh:
Offline An0NyMOUs
  • A Nuisance
« Reply #9 on: March 20, 2016, 08:40:53 pm »
Sorry I should have worded it better, I meant like 'are you sure they're a good idea'. While on the subject though, what are you guys running in your main beams? I.e; wattage, colour.
2.0 FSI 4motion
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #10 on: March 20, 2016, 09:16:11 pm »
6000k in mine and same in the fogs  :rolleye:
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #11 on: March 20, 2016, 09:41:36 pm »
No problem buddy,
Ive got 5000k in mine, 35w kit. Yellow H7 in full beam and yellow tinted fog lights
Hope that helps
Offline An0NyMOUs
  • A Nuisance
« Reply #12 on: March 20, 2016, 11:14:30 pm »
Yeah I've got 4300k 55w low beams, yellow fogs too. Main beam is just a bit boring, might try some better bulbs
2.0 FSI 4motion
Offline Danknott15
« Reply #13 on: March 21, 2016, 11:12:11 am »
What sidelights is everyone running? Didn't know whether to get led bulbs or just the capless 501 bulbs? Also dunno whether to go for white sidelights or run Amber ones so it looks Amber across the whole bottom strip?
Offline bluebert92
« Reply #14 on: March 21, 2016, 11:18:07 am »
a decent set of LED's will smash the standard halogens out the park mate, I've personally gone with white LEDs, although I have Amber DRLs activated I quite like the look of it
