Author Topic: My Black 3 Door Manual ED30 No2297  (Read 37973 times)
Offline ChrisGT
Re: My Black 3 Door Manual ED30 No2297
« Reply #45 on: March 09, 2017, 12:05:29 am »
Looks awesome!  :happy2:
Chris
Offline csrigo
« Reply #46 on: March 09, 2017, 03:29:15 pm »
Chris
Cheers mate  :happy2:
Offline csrigo
« Reply #47 on: September 23, 2017, 10:56:28 pm »
Thought id stick an update up since i hevent in a while.
Well I upgraded the clucth to a Helix organic stage 1 and a new DMF. Car feels night and day as it was slipping something crazy near the end there.
Car currently has:
Tarox grooved and dimpled disks and pads all round
Michelin Pilot V3s
Stage 1 APR remap
H&R Dampening and height adjustable V2 coilovers
Stage 1 Helix organic clutch and new DMF etc
Cam follwer changed again recently..tho old one was still perfect..i change every 5K or something.
All new service parts for winter to be fitted shortly ie new plugs(gapped correctly) coil packs filters air, fuel, pollen and oil.
Always run on Millers nano and will get a full change agaun during service as soon as i have the time to do it all.
Anyway heres a few pics after a quick sesh with the DA
Got myself a DA polisher and had a wee go the other day...disnt go for a really abrasive pad to start as it was the first time id used a DA...but it came up great with a polishing pad some poorboys ssr2 and going over again with autoglym super resin then pain sealant then some HD wax. Once i get some proper chemical guys pads i will get proper into it.
« Last Edit: November 06, 2018, 04:03:50 pm by csrigo »
Offline OirishGTI
« Reply #48 on: September 24, 2017, 06:01:22 am »
Nice! :laugh:
Offline Cosmos
  • 376bhp 423lbs torque
  • My Ride: Golf Gti Edition 30
« Reply #49 on: September 26, 2017, 07:32:21 am »
Looks ace  :smiley:
Offline csrigo
« Reply #50 on: September 27, 2017, 12:08:06 pm »
Offline csrigo
« Reply #51 on: November 06, 2018, 03:55:03 pm »
Just a few random pics of the golf...top ones are before DB9 upgrade so the stance is now different will update again later tonight with some recent work carried out and look etc. I feel I need to add I didn't put BP in my car it's genuinely only ever been ran on VPower since I've owned it bar 1 time I was working middle of nowhere and put £30 Tesco 99 in....daft but one of my many OCD things.
« Last Edit: November 06, 2018, 05:26:56 pm by csrigo »
Offline Deano45
« Reply #52 on: November 06, 2018, 10:42:27 pm »
Brakes are looking awesome ....nice one.
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #53 on: November 07, 2018, 11:19:58 am »
Great upgrade!  :congrats:
Niki says Tesco works just as well as VPower. You can use either without worries. :smiley:
Offline csrigo
« Reply #54 on: November 07, 2018, 10:07:20 pm »
Thanks lads they have been on for months but ive not had a chance to update this in a while.
Injectors didnt arrive back from R-tech today so should be tomorrow and ive stuck in a runner flap delete kit while the manifold was off.
Had a serious issue attempting to remove the cam chain adjuster bolt today....sheared the polydrive bit in two! Will stick a few pics up later hopefully. I bought the polydrive bit (Laser) off Amazon as my mate from VW is in OZ so cant get a sneaky shot of tools till hes back...4 weeks meh. The bolt is ok and i got the broken part out no probs...trying anothe one tomorrow :scared:
Offline csrigo
« Reply #55 on: November 07, 2018, 10:10:54 pm »
Laser 10mm polydrive off amazon.....need to try another tomorrow unfortunately...wish me luck!
Offline csrigo
« Reply #56 on: November 08, 2018, 12:08:11 am »
Heres the almost finished results of the valve clean...pictures dont do it justice of how bad they were before the clean. This is my car currently on 114k.
Above is showing cyl4 3 2 1 top to bottom
This is them not actually 100%...i left them overnight to dry out more and gave anotjer go today after that polydrive snapped to give me something to do....will take more pics before installing the manifold.
Offline AntzGti
« Reply #57 on: November 08, 2018, 10:47:08 am »
Your inlet cleaning is really impressive....  :happy2:
It backs up my suspicions that fuel additives, or introducing fuel & cleaner mixes directly through the manifold will never shift that amount of crud.
Can I as how easy was it to remove in the inlet manifold?
Regards
Antony
Offline Caspersmith
« Reply #58 on: November 08, 2018, 06:13:47 pm »
Wow, such a difference!
I'll get R-Tech to do mine when I've got the money.
Sent from my SM-G950F using Tapatalk
Offline csrigo
« Reply #59 on: November 09, 2018, 04:56:43 pm »
Regards
Antony
Cheers mate much appreciated. Took me a good few hours to clean them up. It can be a pain getting the manifold off tbh if your doing it on the driveway like me. I had to remove the throttle pipe from under the car....i have an uprated much thicker intercooler so limits space...id say a good hour to get it off at least. Oh and your right about the spray clean highly doubtful it would remove a significant amount to anywhere near this level as it is thick amd embedded.
Cheers mate...R-Tech didnt clean my inlet valves etc I done that (8 hours worth), R-Tech reconned and tested my injectors only. But i believe they do do that service and the guys down there are spot on very helpful. Im only showing this as most of our cars are in this region of milage probably so worth a wee check.
