Author Topic: P0100 + P0101 + P0299 - Faulty MAF sensor???  (Read 2106 times)
Offline MS1
« on: March 19, 2016, 04:24:59 pm »
Hi y'all
I've been experiencing flat spots at 2000-2500rpm and 4500-5000rpm.
Today I had the car read and it threw up the following fault codes:
P0100 mass or volume air flow circuit malfunction - intermittent.
P0101 mass or volume air flow circuit range/performance problem - intermittent.
P0299 turbo/supercharger underboost - intermittent.
The MAF amps were tested and were fine, but am I right to assume this still doesn't mean the MAF is okay.
The grams per second on idle was 4 and as it began to increase under load, at 2000rpm crashed down to virtually nothing.
I'm heading to R Tech on Wednesday and don't want to go there with any issues and be turned away. Especially as it's a 500 mile round trip.
« Last Edit: March 19, 2016, 05:28:49 pm by MS1 »
R-Tech Map/ Longlife TBE w/200 cell Sports Cat / ITG Maxogen G60 / Loba HPFP / Forge Twin FMIC / Forge TB Hose / R8 Coilpacks / Neuspeed Power Pulley / EBC D&G Front & Rear Discs / EBC Yellowstuff Pads / BSH PCV Kit / Super-Pro Front & Rear / W.A.L.K / APR Torque Arm / 034Motorsport Density Line Engine Mounts / Vibratechnics Subframe Mount / Vibratechnics Dogbone Bush
284bhp / 307lbft
Offline MS1
Re: P0100 + P0101 + P0299 - Faulty MAF sensor???
« Reply #1 on: March 19, 2016, 07:57:16 pm »
Forget that! It's the MAF, disconnected and it drives  like a dream!
284bhp / 307lbft
