Author Topic: rear wheel bearing  (Read 10124 times)
Offline 4d 2006
rear wheel bearing
« on: January 09, 2010, 12:28:52 pm »
Hi im just after a little more info on the replacing of a rear wheel bearing. i searched and found the free pdf files posted on here and it looks straight forward so going to give it a go. Im just wondering what tools i will need if there are any special ones im not aware of. also is there any torque settings anyone is aware of? also does anybody know any thing else that might be of help.
any help appreciated
Lloyd
Offline xxx_mojo_xxx
  • MUBster DUBster
Re: rear wheel bearing
« Reply #1 on: January 09, 2010, 06:09:36 pm »
Have your rear wheel bearings gone?  How many miles was that after?
Offline gillm
« Reply #2 on: January 09, 2010, 06:13:29 pm »
if its like any other vag rear bearing then it will be easy
west tuned gt28 @ 340hp
Offline 4d 2006
« Reply #3 on: January 09, 2010, 11:53:11 pm »
yeah its the passenger left one had a garage check it out. its just done 50k which isnt much my old corsa lasted until 110k before one went. but i hear its quite a common problem on the golf.
Yeah it looks fairly straight forward so hoping it will be.
if any one knows any more then feel free to chip in will be much appreciated.
Phil Mcavity
« Reply #4 on: January 10, 2010, 07:20:36 am »
Are you sure its not tyre rumble your getting??
What tyres are you running?
If you have Dunlop sportmax, they deform across the tread making the rear sound like the wheel bearings are rumbling.
just a thought. Tis a common complaint.
Offline TomB
« Reply #5 on: January 10, 2010, 12:08:25 pm »
Just make sure you have the right size socket, its a bit of a strange size IIRC.  When we did the one on my Ibiza they had to pack a big socket with paper towel to get it off!
Tom
05 GTI - 18" Merc wheels, coilovers, colour coded Votex kit, all waiting to go on.
Offline 4d 2006
« Reply #6 on: January 10, 2010, 12:11:05 pm »
cheers for that mate i did think it was tyre rumble but got it looked at by my local garage and he confirmed it was bearing. its now got worse so i think he was correct
Offline 4d 2006
« Reply #7 on: January 10, 2010, 12:16:33 pm »
thanks mate ill take a trip to my local vw dealer and see what size they say. any chance you can remember? will it be exactly the same?
Offline TomB
« Reply #8 on: January 10, 2010, 04:22:04 pm »
I apologise, just looked on www.vagcat.com and it appears that they've changed the design so its now secured with just 1 M16x1.5x70 bolt.
Tom
Offline 4d 2006
« Reply #9 on: January 10, 2010, 09:46:06 pm »
brilliant mate that will help. wel im getting the bearing tuesday so maybe the weekend will be when it gets done. ill be sure to let you know how i get on and if i run into any problems to look out for if anyone wants to attempt theirs themselves
Offline nc35
  • -Given: 40
« Reply #10 on: February 21, 2010, 09:32:16 pm »
Any news?
Thinking of changing mine, but currently got the dunlop noise.
How much from the dealer?
What tools did you need?
How long did it take?
Lee
No Golf anymore.
Enjoyed the last five years of ownership of Mk5 & 6 GTIs.
Plus an excellent forum for knowledge and new ways to deplete the bank account.
Thank You Everyone.
Offline 4d 2006
« Reply #11 on: February 23, 2010, 08:16:27 pm »
Hi mate sorry taken so long to reply
Got the bearing done on my driveway and it was fairly easy i read one of the guides in this section of the forum under Free Golf Mk5 official workshop manuals one of the wheel bearing ones. its basically remove wheel then brake caliper and disc. once these are removed then take off the dust cover and you will see the bolt that needs removing this is the only trouble i had because i needed a special bit, i think it was a m18 spline, but i got this sorted before i started by taking the new bolt to my local tool supplier. once thats out then its pull of the old hub and bearing ,its one unit, and then fit the new one and replace other parts in reverse order. i used one of the guides to get the right torque settings too.
I didnt buy my new bearing from VW i went to my local parts dealer and it cost me around £55 so not too much and it took me about an hour as it was the first time doing one but it is very easy.
it really is simple and i would definitely reccomend doing it and save some cash dont know what VW would charge but sure it wouldnt be cheap.
hope this helps mate  :happy2:
 Lloyd
Offline nc35
  • -Given: 40
« Reply #12 on: February 24, 2010, 10:07:14 am »
Thanks Lloyd
Been looking for the thank you button but appears to have vanished???
No Golf anymore.
Thank You Everyone.
  • MUBster DUBster
« Reply #13 on: February 26, 2010, 01:32:02 pm »
How do u know the rear bearing needs replacing?  :stupid:
Offline nc35
  • -Given: 40
« Reply #14 on: February 26, 2010, 02:03:38 pm »
You get quite a distincive sound at different speeds.
Hard to describe but an undulating groan/whirr?
If you can jack the car up there should be no play or movement if you tug on the wheels.
But as mentioned, some Tyres can replicate this noise.
I was convinced mine were shot when I got the car. Had a test run out with MatEd30 who diagnosed Tyres
No Golf anymore.
Thank You Everyone.
