Author Topic: Fellow GTI'ers, I need your help about a new GTI Grill Badge...  (Read 6148 times)
Offline mattkgti
  • Amateur MK5 Golf GTI Enthusiast
Hey Guys,
So.  I was thinking about my next very minor small cosmetic mod which was to put the dark red GTI badge on my grill.
I bought one off eBay, it came in the post, I got very excited and then I realised that it wouldn't fit.
It came with two screws as can be seen above which I naively assumed would be fine.  As I came to take the original one off it was clipped on. I still thought this would be fine so I tried to get the screws through the existing clip holes.  Sounded simple enough in my head.
Anyway the screw holes were too far apart or two close together and I didn't really want to drill some new holes anywhere or modify my current grill if that makes sense.
To cut a long story short, does anyone know where I can buy a clip based red GTI grill badge?  OR can anyone tell me if this even exists or am I just making it up?  At the moment I'm going round badge less and I feel like the car is a bit naked.
Thanks in advance and look forward to hopefully a simple answer to my long winded question.
Matt.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Re: Fellow GTI'ers, I need your help about a new GTI Grill Badge...
« Reply #1 on: March 24, 2016, 09:13:32 pm »
I couldn't help you there but you can always buy genuine gti silver badge and paint it red.
I have a brand new one if you're interested.
If not then no worries.  :smiley:
Offline damo24
« Reply #2 on: March 24, 2016, 10:44:15 pm »
Can't believe something has come up that I know about!
I bought the same badge off eBay and soon discovered it wouldn't fit....
Removed the letters from it and my standard gti badge with a hairdryer and pen knife combo & glued the red letters on to replace the original silver....
They don't fit perfectly but I was happy enough with the result....
Offline mattkgti
« Reply #3 on: March 24, 2016, 10:48:51 pm »
@r5gtt That's not a bad shout, something to look into thank you.   :happy2:
@damo24 I did consider it before I sent it back for a refund, kind of regretting it now.  Yours actually looks alright to be fair!  Might re order it and just do that - seems the most economical way/the only way to get that exact red.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #4 on: March 24, 2016, 10:51:03 pm »
@mattkgti good luck with whatever you choose  :grin:
Offline Trow81
« Reply #5 on: March 24, 2016, 11:08:58 pm »
I brought the same badge. You simply have to file down a part or the honeycomb in the grill to make it fit you won't be able to see it and it's less hassle took me 10 mins
Offline damo24
« Reply #6 on: March 24, 2016, 11:28:53 pm »
[/quote]
[/quote]
The red letters are a little bit smaller than the silver but you wouldn't notice from any more than a foot away.
The rear letters have sticky backing so you wouldn't even need to glue them if you can get those- I could only find sets of front badge + rear letters
Offline jayha11
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,97064.0.html
« Reply #7 on: March 25, 2016, 12:24:40 am »
I did exactly the same and filed down the back if the grill so the arms passed through. Easy job and cannot be seen once fitted back together. I went for black on black. Have a look at my thread.
Mk5 GTI > S3 8P > Cupra 300 > Cupra 290 > Mk5 R32
Offline mattkgti
« Reply #8 on: March 27, 2016, 10:33:24 pm »
Thank you!
I've re-ordered my badge  :grin: so do you mean you just filed the bits where it would normally clip on in the red box below?  Or did you literally file part of the honeycomb?
Offline Trow81
« Reply #9 on: March 28, 2016, 02:49:53 pm »
Thank you!
I filed part of the honeycomb. Try to slot the badge in the grill where u want it placed then u will be able to see which bit needs filing down. You won't be able to see it after the badge is in place and it will look great.
Offline mattkgti
« Reply #10 on: March 28, 2016, 03:29:25 pm »
Thank you!
Cheers @Trow81, will give it a go  :grin:
Offline Trow81
« Reply #11 on: March 28, 2016, 03:47:34 pm »
No probs just file back the pre existing parts so the honeycomb is flush its bit fiddly but worth it
Offline GTI8v
« Reply #12 on: March 28, 2016, 04:54:33 pm »
Sllightly off topic, but how easy is it to remove the grill as in your photo?
I want to remove mine to blacken it but ideally needs 24hrs without getting wet, which at the moment isn't goint to happen  :doh:
Offline damo24
« Reply #13 on: March 28, 2016, 07:11:18 pm »
Dead easy- 2 screws on top & 2 holding/under the number plate, two clips on top and it lifts up and out
Offline GTI8v
« Reply #14 on: March 28, 2016, 09:10:27 pm »
Cheers, will give it a go one night.  :drinking:
