Author Topic: Re: Fellow GTI'ers, I need your help about a new GTI Grill Badge...  (Read 667 times)
Offline Trow81
@mattkgti good luck with whatever you choose  :grin:
Thank you!
I brought the same badge. You simply have to file down a part or the honeycomb in the grill to make it fit you won't be able to see it and it's less hassle took me 10 mins
I've re-ordered my badge  :grin: so do you mean you just filed the bits where it would normally clip on in the red box below?  Or did you literally file part of the honeycomb?
I filed part of the honeycomb. Try to slot the badge in the grill where u want it placed then u will be able to see which bit needs filing down. You won't be able to see it after the badge is in place and it will look great.
Offline Trow81
« Reply #1 on: March 28, 2016, 02:50:42 pm »
