Author Topic: Vcds scan results  (Read 4372 times)
Offline Vwgtiking
Vcds scan results
« on: March 30, 2016, 06:35:22 pm »
Need some help. This morning I had no errors but soon as I started the car this afternoon I had the engine mgt light on. Just done a scan. Can anyone help with the below faults pls?
Pls note it's a diesel bkd.
VCDS Version: Release 15.7.3 Running on Windows XP x86
Data version: 20151216
www.Ross-Tech.com
Wednesday,30,March,2016,17:55:37:07515
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 7D
VIN: WVWZZZ1KZ7M035360   Mileage: 253190km-157324miles
Address 01: Engine        Labels: 03G-906-016-BKD.lbl
   Part No SW: 03G 906 021 KK    HW: 03G 906 021 KK
   Component: R4 2,0L EDC G000SG  9970
   Revision: --H02---    Serial number: VWZ7Z0F4157002
   Coding: 0000072
   Shop #: WSC 02856 128 00032
   VCID: 72E12BBC6DB27AAE77-8026
5 Faults Found:
005685 - Powertrain Data Bus
               P1635 - 000 - Missing Message from A/C Controller - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 252693 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 17:14:43
             Freeze Frame:
                    RPM: 882 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 14.67 V
                    Bin. Bits: 00001100
                    Bin. Bits: 00000000
                    (no units): 0.0
005697 - Please check DTC Memory of A/C Controller
               P1641 - 000 -  - Intermittent
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 253146 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 18:24:04
             Freeze Frame:
                    RPM: 0 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 11.70 V
                    Bin. Bits: 00001100
                    Temperature: 12.6°C
                    (no units): 16.0
012547 - Motor for Intake Manifold Flap (V157)
               P3103 - 000 - Malfunction
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 2
                    Fault Frequency: 5
                    Reset counter: 255
                    Mileage: 253173 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 17:41:36
             Freeze Frame:
                    RPM: 1806 /min
                    Speed: 45.0 km/h
                    Load: 33.3 %
                    Voltage: 14.52 V
                    Bin. Bits: 00001000
                    Torque: 280.6 Nm
                    Torque: 158.6 Nm
001681 - Fan 1 Control Circuit
               P0691 - 000 - Short to GND
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 253173 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 17:41:40
             Freeze Frame:
                    RPM: 1764 /min
                    Speed: 45.0 km/h
                    Load: 0.0 %
                    Voltage: 14.52 V
                    Bin. Bits: 00001000
                    Temperature: 85.5°C
                    Duty Cycle: 9.7 %
012545 - Motor for Intake Manifold Flap (V157)
               P3101 - 000 - Open or Short to Ground - Intermittent
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 253183 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 17:03:16
             Freeze Frame:
                    RPM: 1386 /min
                    Speed: 20.0 km/h
                    Load: 0.0 %
                    Voltage: 14.52 V
                    Bin. Bits: 00001100
                    Torque: 183.0 Nm
                    Torque: 0.0 Nm
Readiness: 1 1 0 0 0
Address 7D: Aux. Heat        Labels: 1K0-963-235.lbl
   Part No SW: 1K0 963 235 E    HW: 1K0 963 235 E
   Component: PTC-Element         0404
   Revision: 00800000    Serial number:
   Shop #: WSC 00000 000 00000
   VCID: 2D5BF8C0B40C6556EA-8078
1 Fault Found:
00361 - Heater Element for Auxiliary Heater (Z35)
            014 - Defective
End-------------------------(Elapsed Time: 01:58)--------------------------
Pls also not I changed the heater controls and have just noticed my old ones said climatic on them whereas my new ones don't. Would this make any difference?
to the ac error codes?
Offline doylebros
Re: Vcds scan results
« Reply #1 on: March 30, 2016, 06:41:02 pm »
I would say the AC panel is causing most of your faults but the intake manifold flap is most likely a blown fuse possibly due to the above panel.
Offline Vwgtiking
« Reply #2 on: March 30, 2016, 06:47:57 pm »
Touchwood. It was the fuse in the engine bay f24, it had blown. Changed it and now doing another scan.
Offline doylebros
« Reply #3 on: March 30, 2016, 06:51:37 pm »
If the fan goes faulty it blows that fuse.
Offline Vwgtiking
« Reply #4 on: March 30, 2016, 07:06:24 pm »
All faults now gone apart from the aux heater. Any ideas on where the fuse is or test it somehow with vcds?
Offline doylebros
« Reply #5 on: March 30, 2016, 07:15:33 pm »
It's easier to follow the wires from the heater box to fault find this- Google aux heater and you'll be shocked of how many cars have went up in flames for loose connections to this heater element - also Google retrofit auxilary heater install and there's some excellent how too's.
Finally, it's a cracking extra/feature in winter for heating your car since it's a diesel but the elements go faulty and are really expensive to replace.
Offline Vwgtiking
« Reply #6 on: March 30, 2016, 09:16:41 pm »
I did an output test and got volts but no current???
Offline doylebros
« Reply #7 on: March 30, 2016, 09:29:19 pm »
Either element open circuit or bad connection.
Offline Vwgtiking
« Reply #8 on: March 30, 2016, 10:00:02 pm »
Looks a little bit of a bitch to remove.
Offline Jmccarron71
  • My Ride: Edition 30 stage 2 bcs power valve
« Reply #9 on: March 30, 2016, 10:10:57 pm »
My 2.0 tdi blew blew a fuse it was intake manifold flap internal fault.it is same fuse as air on and cooing fans.
« Reply #10 on: March 31, 2016, 12:48:17 am »
my aux heater hasn,t worked for years;its a fiddly job so left it for now
Offline Vwgtiking
« Reply #11 on: March 31, 2016, 03:47:05 pm »
My aux heater works though. But vcds says its defective.
