Author Topic: Going to order a PCV replacement....but...  (Read 4278 times)
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
Re: Going to order a PCV replacement....but...
« Reply #15 on: April 04, 2016, 12:53:29 am »
I have just read that if one replaces the PCV with the latest revision, that is 06F129101P, you must replace the rear breather pipe as well. 06F129101P replaces 06F129101G & 06F129101E.
Offline Gmac
  • -Given: 30
« Reply #16 on: April 04, 2016, 05:25:42 am »
From what I've read depending on your VIN, then you were given P or N by the dealer, (N was for early cars) but these have both been replaced by R.  But I can't find info about whether or not the check valve is required when going with the R.  I believe you didn't need to if you replaced with the N.
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
« Reply #17 on: April 04, 2016, 07:33:07 am »
Check valve is not required with the latest R revision, as was not needed for the N. Only the P needed it.
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
« Reply #18 on: April 04, 2016, 09:27:04 pm »
I too have only found that you need to install the latest version-rear breather, with that check valve, if you install the P-version PCV.
Offline mra12345
« Reply #19 on: April 05, 2016, 08:41:39 pm »
So to confirm guys do I replace with 06F129101P or 06F 129 101 R? Looking to confirm before getting my 06 plate booked in for a few jobs.
Thanks!
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #20 on: April 05, 2016, 08:47:57 pm »
Get the latest "R" revision
