Author Topic: Tried the climate control secret display with weird results.....  (Read 648 times)
Offline ReflexRob
Basically I wanted to try 2 data areas on my 2005 AXX car:
1/ Speedo (19.1 position)
2/ Engine coolant temp (19.2) as my gauge only gets to half way when driving normally.
It turns out that 19.0 on mine is speed in KMH and 19.1 is water temperature. I don't have speedo in mph either.
Anyone else had this?
Offline cooljimy84
    • Personal
Re: Tried the climate control secret display with weird results.....
« Reply #1 on: April 01, 2016, 12:53:07 pm »
yep, same on my AXX 2005 GTI as well.
I gave up in the end as i couldn't find out which was which. ended up getting a OBD adapter as that has some simple bits to get.
There is no replacement for displacement....
But a turbo does help....
Offline ReflexRob
« Reply #2 on: April 01, 2016, 05:24:13 pm »
Thanks - bit weird isn't it!
