Author Topic: Can you go lower on KW v1?  (Read 964 times)
Offline K9
  • VW LifeStyle
« on: April 03, 2016, 01:29:54 pm »
Sup. Have my front coilovers KW v1 maxed out on the front, os there anyway to get the front down 1"? shorter springs etc? ideas?
Offline AJP
  • -Given: 392
  • -Receive: 316
Re: Can you go lower on KW v1?
« Reply #1 on: April 03, 2016, 02:00:42 pm »
I know on the mk4 platform you could use Polo topmounts to gain 10mm or so. Maybe a similar solution with the mk5.
You could get some shorter springs made up like you say, but you're probably going to be running the dampers outside of their intended range.
