If your getting power from the fag socket no need to go overhead. run the cable under the steering wheel down the footwell trim. All the sill trim can be moved and the cable tucked in behind without removing including the C pillar. watch the air bags. EASY does it. Piece of stiff wire will help drag the cables through
Did this for my dab antenna. Wonder if there is a wifi camera suitable
