Author Topic: Dubvrs 2008 GTI restoration and upgrade  (Read 71568 times)
Offline ReflexRob
Re: Dubvrs 2008 GTI restoration and upgrade
« Reply #75 on: June 26, 2016, 10:03:38 pm »
An inspiring project - where are you based?
Offline dubvrs
« Reply #76 on: June 26, 2016, 10:31:46 pm »
Based in Midlands Stoke on Trent.
Offline dubvrs
« Reply #77 on: July 01, 2016, 07:58:59 pm »
Managed to get the afternoon off and nip down my mates workshop for a bit of time on the golf.
Old exhaust off and start on the new. Relentless 3.5" down pipe going on. Bitch to get the old one off though.
Went on easier than the old one come off.
Got the BCS all mounted up but run out of time so need to do a bit of adjustment once it has settled.
Sounds a lot better than the standard exhaust.
Polar FIS turned up today and Focal front speakers have turned up just need some good weather to get them fitted.
Offline aaron92
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,107138.0.html
« Reply #78 on: July 01, 2016, 08:41:38 pm »
Did you build your sub box yourself or buy it ? As I really like it and I have a baby so have a pram in my boot most the time so can't have a normal sub
Offline dubvrs
« Reply #79 on: July 01, 2016, 08:47:18 pm »
Got the sub box off eBay. http://www.ebay.co.uk/itm/VW-Golf-MK5-MK6-Custom-Fit-MDF-10-Sub-Box-Subwoofer-Enclosure-Bass-MKV-MKVI-/370799663953?hash=item565561db51:g:U08AAOSwGotWn-wG
Offline Dan648v
  • -Given: 28
« Reply #80 on: July 01, 2016, 10:39:22 pm »
Smart build so far!  :happy2:
Where did you get the carbon pillar trims from?
Offline white91
« Reply #81 on: July 02, 2016, 02:21:52 pm »
Some great mods there
Offline dubvrs
« Reply #82 on: July 02, 2016, 03:58:56 pm »
Came of my mates mk5 as he was selling it.
Spent most of this morning doing the Polar FIS advanced. Pain in the Arse to get the canbus gateway out. Needed the firmware updating but works great. Taken a while to program the screens but pics below.
Just need to decide on an intercooler then I have everything for a stage 2 map.
Offline Craig Stanley
« Reply #83 on: July 02, 2016, 06:55:38 pm »
Hi. Will these Highline clocks be able to replace midline clocks on a 2005 gti and with programming is it possible to have the same screens and info. Cheers
Sent from my SM-N910F using Tapatalk
Offline AJP
  • -Given: 392
  • -Receive: 316
« Reply #84 on: July 02, 2016, 07:10:05 pm »
You need Polar FIS installed to get all that info on Highline clocks.
Offline bad devotions
  • -Given: 19
« Reply #85 on: July 03, 2016, 08:51:02 am »
Not been up to a lot on the car lately as sorting out a new car as the Vito was racking up the miles. Pick up a Mercedes E300 Bluetec Hybrid on a 15 plate tomorrow. Will do me for a couple of months until my pickup arrives.
Got back on the golf today though.
Fuel filter replaced as old on looked like it had been on a while.
THS uprated lower engine mount which was a pain in the Arse but loads better than the old sloppy oem one. Bit of vibration but should loosen up once I get some miles on it.
Got the brembo front and rear discs plus pads. Rear inner pads had siezed.
12mm spacers added alround with longer black anodised bolts and lockers. Fills the arch's a lot better.
Managed to pickup a BCS prestige exhaust up for £400. Ordered a Relentless 3.5" decat down pipe to go with it.
Still waiting for my speakers but they are on back order. Will get the tracking done tomorrow once I have picked up the new car.
Wheels look much better with the spacers.. did you have to get tracking re done after?
Sent from my Nexus 5 using Tapatalk
Offline dubvrs
« Reply #86 on: July 03, 2016, 09:21:02 am »
I did get the tracking done after but only because I removed the subframe to replace the lower engine mount. If I had only done the spacers and brakes I would not of got it done.
Offline dubvrs
« Reply #87 on: July 03, 2016, 04:33:17 pm »
Managed to get my quick shift on this morning. Feels a lot tighter now.
Spent this afternoon giving it a good clean. Looks ok but still needs work and a bit of paint.
Ordered a Anti lift kit and managed to get some bits off my mate who is selling his Gti. Got a set of R32 rear lights and a unused Intercooler and pipes. Looks like a eBay version 2 in black but got it for free so will get it put on.
Offline Stupots
  • -Given: 18
« Reply #88 on: July 03, 2016, 05:06:59 pm »
Id be interested to see what you think of the eBay version 2 intercooler. They look like they have the same measurements as the Darkside one, so like the S3, but with bigger inlet/outlet I believe?
Great build thread, lots of useful info!
Offline white91
« Reply #89 on: July 03, 2016, 06:14:45 pm »
Any tips for fitting the quick shifter?
