Author Topic: Front fog confusion  (Read 5275 times)
Offline damo24
Front fog confusion
« on: April 07, 2016, 12:43:32 pm »
Fully prepared to take the 'f'in noob' responses if warranted but I promise I have searched- manual, Google, and 28 pages of results in here, with no joy so here goes....
Just changed the bulbs on the front fogs figuring the most obvious solution was likely the best but- how do I turn them on?
My switch looks like this so only one 'click' outwards which turns on the rear only, I have tried every setting on the switch & main beams and nothing turns the fronts on.
Has the switch been replaced perhaps and needs changed back?
Offline Nasir
Re: Front fog confusion
« Reply #1 on: April 07, 2016, 12:51:44 pm »
Odd. You don't have the symbol for front fog lights. Usually it's a double pull towards you. Is it an import?
Shadow Blue 2007 GTI DSG (Standard)
Offline Adam0604
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,97534.0.html
« Reply #2 on: April 07, 2016, 01:00:51 pm »
Yeah usually another symbol on bottom left side of the dial .... not sure why you don't have it
Offline damo24
« Reply #3 on: April 07, 2016, 01:04:42 pm »
Thanks for the replies- at least gives me some comfort that I'm not being an idiot!
It was originally bought from a main dealer here in NI so not an import afaik.
The manual shows the switch with the two symbols that's why I wondered if maybe the switch might have been replaced.
« Reply #4 on: April 07, 2016, 01:37:38 pm »
Yeah its a double pull on the switch but yours is just for rears,this is mine
« Last Edit: April 07, 2016, 01:40:17 pm by maxitrol »
Offline damo24
« Reply #5 on: April 07, 2016, 02:08:05 pm »
Yeah that's what the picture in the manual looks like- they are wired in so its not as if they are dummy lights just there for looks
Offline RedGolfDom
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,99951.0.html
« Reply #6 on: April 07, 2016, 03:05:27 pm »
Could try buying the one with the symbol and trying it, may as well get the mk6 chrome one whilst you're at it looks better  :happy2:
Mk5 golf gt 140
Revo stage 1
Air lift Performance 3p
Offline damo24
« Reply #7 on: April 07, 2016, 04:11:17 pm »
See them on eBay for fairly cheap and looks like an idiot proof job to change so might just give it a try!
Offline neiller
  • -Given: 32
« Reply #8 on: April 08, 2016, 08:16:21 am »
Has your car had fog lights fitted as an after thought and maybe not wired in ? Or maybe there's another switch for them somewhere
Sent from my SM-G920F using Tapatalk
Offline damo24
« Reply #9 on: April 08, 2016, 08:26:28 am »
Well there are definitely wires attached to the bulbs I have just changed so I don't think they have been fitted just for show- have looked for another switch as well and can't see one anywhere.
Kind of glad I'm not the only one puzzled by this!
Offline The Red Warrior
« Reply #10 on: April 08, 2016, 11:33:13 am »
Do you have a mate near by with a golf (or probably lots of different vdubs use the same switch) that you could try that has both fog options?
Literally less than a 5 minute job to swap them over, test and swap back again.
Offline damo24
« Reply #11 on: April 08, 2016, 02:38:24 pm »
Top idea thanks!
Offline damo24
« Reply #12 on: April 14, 2016, 11:17:13 am »
Jobs a good 'un thanks gents!
Offline RedGolfDom
« Reply #13 on: April 14, 2016, 05:04:12 pm »
Nice glad it worked out
Mk5 golf gt 140
Revo stage 1
Offline damo24
« Reply #14 on: April 14, 2016, 06:36:12 pm »
Sadly the switch arrived just as my love affair with this particular mk5 draws to an end- a sorry tale I will tell once all is resolved and the dust settles!
Already on the lookout for my next one....
