Author Topic: mfd2 vcds  (Read 1969 times)
Offline kierhanlon6
mfd2 vcds
« on: April 07, 2016, 11:01:06 pm »
having a night mare trying to code my aux output to my stereo so i can play songs from my iPhone. any help with vcds what codes i have to put in to make this work. its doing my head in. i have the mfd2 navi head unit and the double apex aux port.
cheers
Offline Nasir
Re: mfd2 vcds
« Reply #1 on: April 07, 2016, 11:08:11 pm »
You need to code in a CD changer. Go into long coding help.
Shadow Blue 2007 GTI DSG (Standard)
Offline kierhanlon6
Re: mfd2 vcds
« Reply #2 on: April 07, 2016, 11:26:30 pm »
I have a 6 disc cd changer under my arm rest. I brought the proper wiring harnes for the mfd2. Thinking about buying the correct lead to replace the disc changer for the aux lead. Do U know how I code the radio?
Offline Nasir
Re: mfd2 vcds
« Reply #3 on: April 07, 2016, 11:48:02 pm »
The MFD2 does not have aux in support. It only works by emulating a CD changer. You need to disconnect the 6cd changer in order for the emulator to work. How have you connected it up?
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
Re: mfd2 vcds
« Reply #4 on: April 08, 2016, 08:16:11 am »
Second that. I have an MFD2 also and if I want iPod connection I need to remove the CD changer.
Your other option is an aftermarket connection system such as xCarlink which keeps both!
Offline kierhanlon6
Re: mfd2 vcds
« Reply #5 on: April 08, 2016, 10:10:42 am »
I have connected up with the mfd2 harness straight in the back of the head unit and left the main working loom alone. So which one do I disconnect from the main wiring loom do you know? I brought it from the double apex website there was a couple of options. And I thought the easiest would be the wiring harness for mfd2 but being nothing but problems. Thanks for all your help. Will have a go tomorrow taking the head unit back out and disconnecting the cd changer will try and work out which one it is. Think there is 2 little ones one is blue and the other is white and the main one black I think. Cheers
Offline Nasir
Re: mfd2 vcds
« Reply #6 on: April 08, 2016, 11:55:46 am »
IIRC, the blue is for the CD changer. You need to take that out of the quadlock and plug in your emulator. Shouldn't require coding.
Offline kierhanlon6
Re: mfd2 vcds
« Reply #7 on: April 09, 2016, 10:01:44 am »
ok brilliant so take the blue out of the quad lock and plus the aux harness in to the port already for the aux port? cheers
