Author Topic: rear wiper motor  (Read 1905 times)
Offline kierhanlon6
rear wiper motor
« on: April 10, 2016, 08:44:54 pm »
hello my rear wiper motor keeps getting suck at random points of the wipe is this a easy fix or a whole new motor? any help please cheers
Offline doylebros
  • -Receive: 310
Re: rear wiper motor
« Reply #1 on: April 10, 2016, 08:55:18 pm »
The most likely fault is the wiring in the tail gate flexi connectors at the top - the problem is there are different levels of repair
http://www.mk5golfgti.co.uk/forum/index.php?topic=86689.0
New harness expensive but little in the way of tools required
Or
Cut out broken/failed section solder in new and retape into existing harness - cost very little if you have access to the required tooling?
Offline kierhanlon6
« Reply #2 on: April 10, 2016, 09:09:01 pm »
Or
cheers for the response. where is the most common are just in the flexi that meets the body to the boot?
Offline doylebros
  • -Receive: 310
« Reply #3 on: April 10, 2016, 09:14:07 pm »
Yes but be careful since the wires for the wiper are all White coloured ones and if broken you'll have to do a bit investigative work to match them up for repair.
Offline kierhanlon6
« Reply #4 on: April 10, 2016, 09:16:14 pm »
ah perfect thanks for the help will try and pull the rubber back to expose the wires hope it will be easy enough
