Author Topic: DIY - Cam Chain and Tensioner Guide  (Read 303151 times)
Offline smully
Re: DIY - Cam Chain and Tensioner Guide
« Reply #105 on: September 26, 2024, 03:06:12 pm »
Afternoon all. I'm new on here but have been watching form a far since purchasing my Mk5 last November. The tips have come in super handy. Cheers all.
I'm  considering doing this job myself. My only question is how important is the chain going on specific links as per the write up? I've seen and read elsewhere that you have to count back from the coloured link and line it up on the sprocket  etc. etc. but on an aftermarket kit, there doesn't seem to be a coloured link, so I'm a bit confused... I get the cams need to be in a certain place and the adjuster need to go on a specific way but I cant see what the importance of the chain being on a certain tooth is? Cheers in advance.
Offline mjmallia
  • -Receive: 59
« Reply #106 on: September 27, 2024, 08:26:05 am »
That applies to the genuine stuff and is what I would recommend using.......not a job you want to redo.
I assume on aftermarket stuff you just need to make one of the links the anchor to count off from.....use a marker on it to stand out.
Mike
South Coast
Offline smully
« Reply #107 on: September 27, 2024, 10:07:19 am »
Thanks Mike.
Still not sure what difference it'd make though, surely the chain can just be fitted anyway you want?
Offline mjmallia
  • -Receive: 59
« Reply #108 on: September 27, 2024, 11:59:13 am »
Because there is slack in the chain, until you pull the tensioner pin.  If one link is out then not a good thing for the engine
Mike
South Coast
  • -Receive: 692
« Reply #109 on: September 27, 2024, 01:39:30 pm »
Coloured links are a fitment aid only and not critical.  They are more common and useful on engines with several sprockets, but on the GTI with only 2 sprockets, it's no big deal.
So long as the cams are in the right position, you're golden. Just remember to tweak the inlet cam a few degrees anti clockwise when fitting the chain to make sure it has the correct tension. In other words, if the variator sprocket doesn't go straight on, tweak the inlet cam until it does.  Lots of folk skip that (it's in the VW repair manual and they do a tool for it) and end up being a tooth off afterwards.
Think carefully about your parts choice because there is a lot of trash in the aftermarket and it's not a job you want to do more than once, especially it the car is a keeper.
Offline smully
« Reply #110 on: September 27, 2024, 02:03:19 pm »
Perfect, that's what i needed to know. Many thanks. Yep, couldn't work out all this counting links stuff... As long as the cams line up. Will be using genuine VAG stuff for sure. Cheers all.
