Hi guys,
still having few issues since replacing the inlet camshaft, timing chain and tensioner. the car is currently shaking like mad on idle, misfiring count on cylinders, but it seem's to drive well...
now the only fault code that keeps coming back p000a slow intake response...which would suggest the timing is incorrect but i've checked using the tool with the engine set on bang tdc multiple times now
![thinking :thinking:](https://www.mk5golfgti.co.uk/forum/Smileys/newsmileys/thinking-hard-smiley-emoticon.gif)
, the tool had a little bit of play when placed between the inlet and exhaust camshaft which by looks of things should be correct..
in the last month, i've done the following...
*cleaned oil pick and fresh oil
*replaced the 3 oil separator rings found inside the vvt adjuster
*degreased and cleaned the timing chain cover
*cleaned the n205 valve and also done output test with vcds seemed fine
*compression test results were 160-170psi
*throttle body adaptation
*pcv valve replacement
*dv upgrade to gfb
*tested coil packs and replaced spark plugs
today I managed to check the 91/93 measuring blocks here are the results below...as you can see something still's not right! I'm sure the phase position bank 1 intake shouldn't be as high as 4.0kw...i could be wrong though?!?!
(picture link below sorry can't work out how to get images onto this forum atm)
https://ibb.co/bEE9q6currently borrowing my university's hex+can cable so i can use vcds on my car but i need to give it back by Wednesday so need some suggestions very quickly.
any help would be much appreciated
sam
