Author Topic: Knocking when turning right under acceleration  (Read 6315 times)
Offline Northy1985
  • Instagram o_n02thy
« on: April 13, 2016, 10:24:08 pm »
I noticed today that when i turn right and accelerate slightly i get a knocking from gearbox/driveshaft passenger side only but once i have drove the car for a while it dont happen. Its only when cold almost like the passenger driveshaft is pushing into gearbox
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Re: Knocking when turning right under acceleration
« Reply #1 on: April 13, 2016, 10:40:23 pm »
Check the bolts haven't come loose.
CV joint?.
Offline Northy1985
« Reply #2 on: April 14, 2016, 06:35:03 pm »
Checked the bolts earlier all nice and tight even spun the wheel and no noise but soon as i driver her noise is there then goes after a few miles
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #3 on: April 14, 2016, 07:32:50 pm »
Something must be loose but I'm afraid I couldn't pin point it wohout being there.
does it sound more like a clatter clatter clatter noise?.
Offline Northy1985
« Reply #4 on: April 14, 2016, 08:03:06 pm »
I I just took her out again and from cold the noise was there almost like imaging holding a screwdriver over a sprocket. It's strange it rolls round no noise slight acceleration under load noise there sounds from gearbox. Then few miles and once warm perfect no noise no matter how I driver her
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #5 on: April 14, 2016, 08:13:47 pm »
That's very odd indeed.
Can you upload a video of the noise with any luck?.
Offline Northy1985
« Reply #6 on: April 14, 2016, 08:31:07 pm »
I will see if I can get a video problem is it's not mega loud so may be hard as my car ain't the quietist I just thought can't be a major problem if it stops when warm almost like gearbox oil gets nice and warm and noise stops maybe
Offline Shoy1980
« Reply #7 on: April 14, 2016, 09:11:08 pm »
Have you tried the subframe bolts? Very common problem.
Sent from my HTC One using Tapatalk
Offline AJP
  • -Given: 392
  • -Receive: 316
« Reply #8 on: April 14, 2016, 09:25:12 pm »
Is it a click clack click noise? Dry cv boot?
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #9 on: April 14, 2016, 10:04:37 pm »
If that's the case I'd get the oil level checked just to be sure it's not low.
Offline Northy1985
« Reply #10 on: April 15, 2016, 01:31:05 pm »
It's like a clicking noise I suppose but surely if dry cv joint it wouldn't stop after few miles
Offline AJP
  • -Given: 392
  • -Receive: 316
« Reply #11 on: April 15, 2016, 06:10:16 pm »
You could do with getting it up on a ramp or it'll just turn into a guessing game.
Not sure exactly what it's called but try and find somewhere with one of the ramps that puts each wheel under stress/load laterally. They make it easy to troubleshoot things like this.
Offline boost30
  • Edition 30 from Berlin!
« Reply #12 on: July 21, 2016, 03:27:56 pm »
Did anyone find a solution for this? I have something similar and its only when taking off slowly, as described above a click-clack noise, but after she gets running it stops.
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
« Reply #13 on: July 22, 2016, 09:50:15 am »
Any chance you recently changed your lug nuts?
Offline jon_hill
« Reply #14 on: July 22, 2016, 06:35:36 pm »
Friend of mine had a very similar problem, changed the flushed out the gearbox oil and relaxed with fresh oil and additive and hey presto! Good luck
