Author Topic: Headlight washers & tailgate handle/badge  (Read 1505 times)
Offline holepunch
« on: January 12, 2010, 07:37:04 pm »
Couple of quick questions,
Is it right that each time I use my windscreen washers the headlight ones operate.  I could have sworn I read somewhere they were suppose to come on every 5th use of the windscreen ones?
Also the tailgate badge/handle is failing to return to its normal postion Iie flush with the boot) after opening.  I assume I have to replace the whole unit rather than just the return spring?  Can anyone help with part numbers, prices and or a fitting guide.
Thanks in advance
Rob
Re: Headlight washers & tailgate handle/badge
« Reply #1 on: January 12, 2010, 08:00:30 pm »
Regarding your tailgate handle, My car is in at VW at the moment, as they are replacing the cambelt tensioner and belt. I had exactly the same problem with the handle sticking, so I asked if they could look at it and maybe lube it up  :ashamed:
They called today and said they need to replace the handle  :confused: :confused: :confused:
Offline Golfgirl
« Reply #2 on: January 12, 2010, 08:37:41 pm »
Headlight washers come on with the first and every fifth wash.
FOR SALE!
gaz b
« Reply #3 on: January 12, 2010, 08:50:12 pm »
I thought it was only when the headlights were on!  :embarrassed:
Offline njdudsbury
« Reply #4 on: January 13, 2010, 12:48:29 pm »
Might washers on the lights come on every time I spray the screen only when the lights are on.
Is the fifth wash onlt when the lights are off?
Offline FamilyDub
  • ...who needs a diesel?
« Reply #5 on: January 13, 2010, 12:58:51 pm »
^^^^^^^^ +1
MKV GTI | Reflex Silver | 5-dr, Family-Spec | 17" w/anthracite Finish | Manual | Highline | Cruise | Revision 'D' DV | Dirty Pipes |
