Author Topic: Golf Mk5 Gti Intercooler vs Edition 30  (Read 34591 times)
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
Re: Golf Mk5 Gti Intercooler vs Edition 30
« Reply #15 on: April 15, 2016, 07:25:06 pm »
IMO, a 350 BHP Ed. 30 only needs a S3 IC. If you're looking for more than that (stage 2+), I'd save a bit more to get a Peron/Wagner/Airtec stage 2/Forge FMIC that cost around £ 550.
For a cheap upgrade the Chinese THS replicas seem good enough (I've seen people saying that they got 365 BHP with them, if I'm not mistaken). Mine from Darkside Developments was £ 300 with discount. The only advantage I can wonder they have over the S3 IC is that they cool very fast. At WOT the temps rise likewise. That was what my tuner said and he has a lot of experience with the S3 IC.
Offline jacobrownoly
« Reply #16 on: April 15, 2016, 08:52:08 pm »
I got a airtec stage 2 for £500 and was one of the best mods I did. It's a big job but worth it. With stock IC I lost 41 bhp on back to back dyno runs on stage 2+ which was useless! Soon as I got the airtec stage 2 I made 277 bhp and lost 1 bhp on back to back runs!
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #17 on: April 15, 2016, 09:08:50 pm »
A K03 doesn't need more than a S3 IC. Ask Niki Gower about it. :wink:
The S3 IC has the size and the flow that compliment well the K03 performance. :smiley:
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
« Reply #18 on: April 16, 2016, 01:22:47 am »
I agree the K03, if tuned, should only need a larger oem location fmic or an additional twin cooler by Forge coupled with the oem fmic. If you upgrade the turbo to a K04 I'd suggest the S3 or other oem location fmic and if you run it hard for a good duration in a day from time to time...add an additional twin cooler. I have the Audi S3 coupled with the Forge twin cooler along with a K04. Boost-actual peaks within 600 to 700 rpm of the start of a 3rd gear pull when data is collected. I'd say no boost lag there. Any amount of throttle at any time is so very responsive as well. I run 12.8s 1/4 mile ET's all day at the track...so no heat-soak either. If I did long road track events I could comment and share those results, but I don't do that. Hoping to get into hill-climbs soon though  :happy2:
« Last Edit: April 16, 2016, 01:24:44 am by ROH ECHT »
Offline dronners
« Reply #19 on: April 16, 2016, 11:46:04 am »
or keep your stock intercooler and add a twintercooler
Not sure if a S3 IC wouldn't be better due to the lag and pressure drop... Personally for what I know I'd choose a S3 IC over that option. For BT you can add a twintercooler to a S3 IC, I guess.
i have the airtec twin cooler. there is no noticeable increase in turbo lag from what i can feel
How is the fit? is there any bumper trimming?
a little bit around the fog light mounting for the hose's to clear but otherwise a very good fit
Offline Paradox1
  • -Given: 41
« Reply #20 on: April 18, 2016, 10:32:31 am »
Thanks for this.
I did think of one of the EBay OEM style coolers along with a ebay twintercooler (still cheaper than most on the market) thought this would futureproof me incase I ever decided to change to a BT setup.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #21 on: April 18, 2016, 01:19:30 pm »
We wish it was bigger, indeed. Put a TBE with sports cat (or decat), fit a bigger IC (S3 or bigger) and fit an upgraded HPFP (LOBA, APR, Autotech internals) and with a stock map you can see 270 BHP, which is the same as the S3 engine makes from factory.
are you saying @Shoduchi that the above parts fitted to a standard gti can produce an extra 70 bhp without having to Map it?.
Offline Paradox1
  • -Given: 41
« Reply #22 on: April 18, 2016, 01:49:17 pm »
No way, you'd definitely need a map
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #23 on: April 18, 2016, 02:51:55 pm »
@Paradox1 that's what I thought as how would fitting parts alter timing fuelling and air.
Offline Paradox1
  • -Given: 41
« Reply #24 on: April 18, 2016, 03:00:29 pm »
Yeah that's it. you could have all the bolt on but would make any noticeable power I don't think.
As you know a map makes the biggest difference
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
« Reply #25 on: April 18, 2016, 03:03:20 pm »
He's talking about the Ed30 - not the GTI
FYI the Darkside cooler is no different to the £170-200 china THS copies - work plenty fine on a K03 car. I have a china copy and mine and can hit peak boost below 3k rpm.  What is totally overkill are the massive wellycoolers people fit. Be warned - china couplers do NOT fit. The best fitting one I have found is from SFS
The standard cooler is not good at all. 20 degrees C + above ambient is a LOT. Mine on WOT is always less than 10 degrees above ambient with the meth off (Still have a/c rad). Switch the meth on and its within 1-2 degrees either side of ambient.
« Reply #26 on: April 18, 2016, 03:16:16 pm »
Mine on WOT is always less than 10 degrees above ambient with the meth off (Still have a/c rad). .
Even after 10 pulls to the redline on a 28 deg summer's day?  I'm calling BS on that, pending VCDS logs as proof  :smiley:
Offline Paradox1
  • -Given: 41
« Reply #27 on: April 18, 2016, 03:19:47 pm »
How is your meth nozzle setup?
TB spacer or Throttle body pipe?
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #28 on: April 18, 2016, 03:26:27 pm »
You can compare my dyno runs before and after mapping. The engine was pretty consistent achieving the 270 BHP on that BAPRO dyno.
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
« Reply #29 on: April 18, 2016, 03:27:30 pm »
Can't say I've ever tried 10 back to back runs on a summers day. Lot of variables to consider too, but whenever I logged my car before fitting the meth, which included leaving the thing plugged in and logging the entire 'session', on a WOT run the IAT at the top of a gear was within 10 degrees of ambient. On the standard cooler it went a lot higher
Don't get me wrong the cooler will heatsoak in slow moving traffic/town cruising the same as any cooler will, but when theres plenty of airflow at 'motorway speeds' then it does its job very well
Meth is in a TB spacer. Temps given are again at the top of a gear. The second you lift off (while there is some meth still injecting), the super cooling effect makes the indicated IAT plunge to 10-15 degrees below ambient for a few seconds :smiley:
