Author Topic: RCD310 DAB Radio - Advice  (Read 1056 times)
Offline Gooky
« on: April 18, 2016, 06:37:27 pm »
Hi Guys an Girls,
Im looking in to upgrading the stand radio in a 2007 edition30 too RCD310 DAB radio, wood I need to upgrading the bus gateway in this as I had a 2006 Gti in wish I did the same an had the battery drain problem till I got a new one, Is it the same on all MK5 Golf's..   :thinking:
Offline cenobytez
Re: RCD310 DAB Radio - Advice
« Reply #1 on: April 19, 2016, 12:05:17 pm »
later ones did not have the battery drain problem, not sure on the ed30, but I would say say, you will still need to upgrade the canbus
Offline Horatio
  • -Receive: 39
« Reply #2 on: April 20, 2016, 09:48:19 pm »
When I had the gti, it was registered sep07 and didnt need a newer can. Not sure when the build date was  :thinking: if you know anyone with vcds they can scan your car OR call up your local VW dealer and speak to the parts dept, give them your reg number and they can tell what version is  :happy2:
Offline Gooky
« Reply #3 on: April 21, 2016, 05:31:41 pm »
Thanks guy's ill give vw a ring see what then say nice1  :happy2: :happy2:
