Author Topic: Engine very low temperature  (Read 9768 times)
Offline sub39h
  • -Given: 189
  • -Receive: 84
Re: Engine very low temperature
« Reply #15 on: April 21, 2016, 10:40:04 pm »
Probably the thermostat. I got mine replaced last summer and it fixed the same problem last summer.
Mine was timed with a cambelt/water pump change so I only had to pay for the coolant once but it's fairly cheap if you're not due a change.
PLANS: Stage 2+
Offline zayd
« Reply #16 on: April 23, 2016, 03:16:50 pm »
I just had my thermostat replaced due to eratic temp behaviour on the guage.  Now, after a couple of miles driving it gets to 90 and stays there.  This is how it should behave and anyone telling you otherwise is telling porkies. There is a coolant temp sensor that also does go faulty, but usually the thermostat is the culprit in these cases.
