All, looking to see if anyone has any experience on buying/fitting/using a source to track your cars, in the event of them going walkies....Cheers
Quote from: D Squared on April 21, 2016, 10:49:07 amAll, looking to see if anyone has any experience on buying/fitting/using a source to track your cars, in the event of them going walkies....CheersYes. used a cheap £30 once. just hooked it up to the constant live 12v feed. added sim card to it, mounted the unit,gps and gsm antenna somewhere discreet and away you go. you call the number and after 2 rings it messages you a google maps link to your car and is very accurate. also has a backup battery in case someone removes your car battery.
Yep still working, you can also hook it up to the fuel supply somehow and remotely shut down the car and lock the car. But i just used it for simple tracking https://www.amazon.co.uk/gp/aw/d/B003XDN58K/ref=ya_aw_od_pi?ie=UTF8&psc=1Sent from my SM-G928F using Tapatalk
Quote from: RetroRaz on April 21, 2016, 10:52:09 amQuote from: D Squared on April 21, 2016, 10:49:07 amAll, looking to see if anyone has any experience on buying/fitting/using a source to track your cars, in the event of them going walkies....CheersYes. used a cheap £30 once. just hooked it up to the constant live 12v feed. added sim card to it, mounted the unit,gps and gsm antenna somewhere discreet and away you go. you call the number and after 2 rings it messages you a google maps link to your car and is very accurate. also has a backup battery in case someone removes your car battery.I've thought of using an old phone wired to permanent 12v and 'google find my phone', would work in a similar way.
