Author Topic: Tyre size question..18"  (Read 1940 times)
Offline Gmac
  • -Given: 30
« on: April 21, 2016, 03:13:15 pm »
Quick question...
I'm planning new putting H&R lowering springs on and also putting a set of 18" wheels on which are 8j wide..
They come with 235/40/18 tyres... I know normally we'd be looking for 225, but will the 235 cause any rubbing issues????
TIA
Re: Tyre size question..18"
« Reply #1 on: April 21, 2016, 03:39:35 pm »
It might throw the speedo out a little as the sidewall height is a percentage of the width.
Offline jayha11
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,97064.0.html
« Reply #2 on: April 21, 2016, 03:58:59 pm »
Few things that will help:
Whats the offset of the wheels?
Are the springs 30mm drop?
Mk5 GTI > S3 8P > Cupra 300 > Cupra 290 > Mk5 R32
Offline Gmac
  • -Given: 30
« Reply #3 on: April 21, 2016, 07:10:37 pm »
The offset is et43, and the drop is indeed 30mm...
Offline jaffa
  • -Receive: 44
« Reply #4 on: April 21, 2016, 10:21:18 pm »
Probably rub with the 235's
Doing the screw mod will give you a few mm's clearance but you should get some 225's
Offline sub39h
  • -Given: 189
  • -Receive: 84
« Reply #5 on: April 21, 2016, 10:37:33 pm »
I do agree that you should run the right size tyre, but the difference is negligible - 4mm radius or less than 1mph difference at 70mph
http://www.brspecialtuning.co.uk/Tyre%20size%20calculator.htm
PLANS: Stage 2+
Offline jayha11
« Reply #6 on: April 22, 2016, 10:44:15 am »
Just to give you some perspective I am running the following...
18x8j ET35 (stick out 8mm further than yours)
lowered approx 65mm front & back
Tyre's are 215x40x18 to aid with tucking at the rear
Is there a specific reason you want to run 235 tyre's?
Offline Gmac
  • -Given: 30
« Reply #7 on: April 22, 2016, 11:27:12 am »
Yeh, the wheels that are for sale come with 235's.  I've currently got 17" wheels and tyres.
Offline Gmac
  • -Given: 30
« Reply #8 on: April 22, 2016, 11:27:59 am »
Will do a search for the 'screw mod'.  :happy2:
« Reply #9 on: April 22, 2016, 11:59:43 am »
Yeah it's very minor usually, but sometimes one tyre maker's '235' is a bit different to another's.   I usually find taller tyres than standard affect the gearing and unsprung mass more than anything else though!
