Author Topic: Depo Xenon headlight help  (Read 11961 times)
Offline Vithu06
« on: April 24, 2016, 04:07:46 am »
Hey everyone, I've just installed a pair of Depo headlights but notice the dipped beam isn't working tried google but hasn't helped i've got a bulb warning on the dash. also if you flash the lights you bulb turns on but dipped beam doesn't power up on it's own.
The car is currently using H7 for the main and the standard halogen form my old headlight for the dipped beam
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
Re: Depo Xenon headlight help
« Reply #1 on: April 24, 2016, 10:57:14 am »
Have you made sure the wiring loom connector is clicked properly into the headlight?
Sent from my SM-G928F using Tapatalk
Offline Vithu06
« Reply #2 on: April 24, 2016, 02:15:16 pm »
Hey mate i've checked and it's all good
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #3 on: April 24, 2016, 03:40:51 pm »
Swap the bulbs over. Might be your dipped bulbs arent working.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #4 on: April 24, 2016, 04:39:33 pm »
I second what Raz says  :happy2:
Offline Vithu06
« Reply #5 on: April 24, 2016, 04:40:42 pm »
Just checked them and the bulbs work when I flash them. It just doesn't work on it's own on dipped beam and still got the bulb light on my dash. What else can i do? :sad1: it's annoying not having dipped beam :sad1: :doh:
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #6 on: April 24, 2016, 05:57:11 pm »
Have you swopped the bulbs over?.
Offline Vithu06
« Reply #7 on: April 24, 2016, 06:42:05 pm »
What do you mean mate? I'm currently using New H7 for the main beam and used standard type 477 for the another. from what I remember shouldn't the dipped beam be on the same light as the main beam so the projector lens but will swap them around tomorrow thanks a lot for your help. One more thing do you have anymore ideas please I will be grateful if we can resort this issue thanks. :sad1:
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #8 on: April 24, 2016, 07:01:46 pm »
The depo headlights take h7 for both dipped and full beam. It could be the bulbs you put into the full beams work and the bulbs you put in the dipped dont. Thats why i was suggesting to swap them over so you can eliminate it's the bulbs.
Offline Vithu06
« Reply #9 on: April 24, 2016, 08:49:00 pm »
Thanks mate I will try this in the morning
Offline Vithu06
« Reply #10 on: April 25, 2016, 04:24:23 pm »
Hey mate, Swapped the bulbs around like you said and it's still didn't work. I think I need to plug a computer in to find the root of the problem as i'm sure i won't pass a mot if both like don't work. Plugged in my obd2 scanner and it said it had four monitor faults as in for the bulbs. :thinking:
 :sad1:It's annoying as I just want it to be a simply fit. One more thing I checked the harmless and it was in very well I seriously don't know what to do now. Thanks a lot for your help i've honestly been really helpful thanks.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #11 on: April 25, 2016, 05:20:42 pm »
Fuse?
Offline Vithu06
« Reply #12 on: April 25, 2016, 07:25:42 pm »
Fuses are fine but i've got the bulb monitoring light on the dash does this help?
Offline Vithu06
« Reply #13 on: April 25, 2016, 07:30:31 pm »
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #14 on: April 25, 2016, 08:22:01 pm »
I remember this company.i told the guys to first order from these lot. Then someone pointed out they were for left hand drive only. I emailed seller and she said left hand only.
Do you swopped both outer bulbs for inner bulbs and that hasn't worked.
Fuse you say is okay.
only other thing is lights are faulty.
