Author Topic: Replacement of blue speedo/rev counter etc lights..  (Read 7339 times)
Offline WhiteGTI
  • F-A-S-T
« on: December 22, 2008, 05:34:27 pm »
Anyone know how to do this, or know where a DIY guide can be found??
I quite fancy changing my speedo/rev counter etc etc lights from the purply blue to a nice crisp white (as on the S3 and the new GTI). Think it would look pretty damn good with the red needles also!
Ive done this mod on a previous car and it worked pretty well.
Any help would be appreciated ............. :smiley: :smiley: :happy2:
2006 E46 BMW M3 - 343hp
Re: Replacement of blue speedo/rev counter etc lights..
« Reply #1 on: December 22, 2008, 05:40:30 pm »
ive done this mod on a previous car and it was a good mod.
but....i would guess that the LEDs in our clocks are SMDs surface mounted Diodes. these things are tiny.
it would probably involve completely stripping each circuit board (risky) and soldering each SMD on. and i bet theres a good 30 SMDs in there.
i would also guess it be dam near impossible to dissassemble the clocks
Offline WhiteGTI
  • F-A-S-T
« Reply #2 on: December 22, 2008, 05:41:06 pm »
:sad: :sad: :sad: :sad: :sad: :sad: :sad: :sad: :sad: :sad: :sad: :sad: :sad: :sad:
« Reply #3 on: December 22, 2008, 05:41:41 pm »
i know, i do love the white in the MK6. and audis!
« Reply #4 on: December 22, 2008, 05:42:02 pm »
i bet its not impossible but a MAJOR fook around
Offline WhiteGTI
  • F-A-S-T
« Reply #5 on: December 22, 2008, 05:43:58 pm »
lol, to be honest i couldnt be bothered to do it if it was as you have explained above...!!
If anyone else knows of anything then do post! I hope its not as JPC has said, but it sounds pretty likely!
« Reply #6 on: December 22, 2008, 05:47:45 pm »
i ever sum up the bravery to diss-assemble a set of clocks, ill let you know.
i will probably be retro-fitting highline so ill take my midline clocks apart.
all in the name of research! ;)
Offline WhiteGTI
  • F-A-S-T
« Reply #7 on: December 22, 2008, 05:54:13 pm »
:smiley: :smiley: :smiley: :smiley: :smiley: :smiley: :smiley: :smiley: :smiley: :smiley:
Yeah it would definitely be good to know what type of bulb they are  / if its easy to disasemble the clocks! I wouldnt have a frigging clue where to start! :ashamed: :ashamed:
« Reply #8 on: December 22, 2008, 06:07:12 pm »
I'm wondering if the Mk6 aka Mk5.5 instruments cluster will transfer successfully. It's not only clear white but also angled.
Personally I love the blue lighting but I find the speedo display atrocious, especially the kph. I use PogoAlert GPS speed display anyway and the rev counter is clear enough just by needle position rather than accurate readout.
« Reply #9 on: December 22, 2008, 07:14:03 pm »
Red.... as in will the cluster be taken well?
« Reply #10 on: December 22, 2008, 08:52:42 pm »
....Sorry but I don't understand your question :confused:
:smiley:
« Reply #11 on: December 22, 2008, 08:56:53 pm »
forgive me if this turns into a ramble....i have become good at this recently
my question related to this
"I'm wondering if the Mk6 aka Mk5.5 instruments cluster will transfer successfully."
do you mean, you wonder how well the change from blue to white from mk5 to mk6 will be taken?
or did you mean:
you wonder if its possible to lift a mk6 cluster into a mk5?
if you meant the latter, i pretty sure the mk6 cluster is a completely different shape
« Reply #12 on: December 22, 2008, 08:57:42 pm »
or as another option, have i just completely not got what your saying and had too long of a day at work? hehe
« Reply #13 on: December 22, 2008, 09:15:16 pm »
Thanks for explaining, JPC.
I meant is it possible to fit a Mk6 cluster into a Mk5, but obviously not possible if a different shape.
« Last Edit: December 22, 2008, 11:33:59 pm by RedRobin »
« Reply #14 on: December 22, 2008, 10:42:37 pm »
its quite ok, you can call me jay too if you had forgotten my name! you might have miss-heard me as i dont talk properly because im from the north!!!haha!!
from my quick scan of the mk6 in the dealers the other week, i thought the shape of the front plastic shield seem to have a much more concave shape. and i seem to remember the "0,00" button being a lot bigger
