Author Topic: seat belt help  (Read 3320 times)
Offline kierhanlon6
seat belt help
« on: April 24, 2016, 09:49:37 pm »
hello my rear middle seat belt won't come out its stuck and ever so tight once the seat is in upright i can only just about get one finger underneath and once the seat is folded down i can get about 3 fingers under. when trying to pull out it just locks tight. even tried ever so gentle. any one else had this trouble?
cheers
Offline MateyGuv
  • -Given: 32
  • -Receive: 67
  • Instagram & YouTube - mateyguv
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,69555.0.html
Re: seat belt help
« Reply #1 on: April 25, 2016, 12:08:34 pm »
Iv not had this problem but I'd think if they are that tight you could free it by taking the seat out to slacken it a bit then free it off. This video may help - it's installing a brace but there is a bit about taking the rear bench out
Offline kierhanlon6
Re: seat belt help
« Reply #2 on: May 02, 2016, 02:42:26 pm »
still having a night mare with the middle seat belt any one else had this issue?
Offline MateyGuv
  • -Given: 32
  • -Receive: 67
Re: seat belt help
« Reply #3 on: May 02, 2016, 07:58:54 pm »
Have you taken the seat out of the car and tried that yet?
Offline kierhanlon6
Re: seat belt help
« Reply #4 on: May 02, 2016, 09:02:37 pm »
tried to un do the seat belt that is bolted to the car but couldn't find a torx big enough. so will try and take the seat out in the week and try and put some slack in to it. has it happened to you?
cheers
Offline MateyGuv
  • -Given: 32
  • -Receive: 67
Re: seat belt help
« Reply #5 on: May 02, 2016, 09:05:59 pm »
It's not a torx you need but a triple square bit. I can't remember the size but eBay has loads on at little money. It's not happened as bad as it sounds like youv had but Iv taken my interior out a fair few times and I understand how the belts work so if you take the top bench out you'll have enough slack to get the angle right to reset it  :happy2:
Offline MateyGuv
  • -Given: 32
  • -Receive: 67
Re: seat belt help
« Reply #6 on: May 02, 2016, 09:08:08 pm »
Get a set of triple square bits as the MK5 has a lot of them around be the car
Offline MateyGuv
  • -Given: 32
  • -Receive: 67
Re: seat belt help
« Reply #7 on: May 02, 2016, 09:11:10 pm »
Offline kierhanlon6
Re: seat belt help
« Reply #8 on: May 02, 2016, 09:20:36 pm »
your a gent. when you mean top bench are u meaning the bit where you sit? i was thinking of taking the back of the seat off and try to tilt it so it puts slack in the belt.
cheers for the bay link too. will buy them
Offline MateyGuv
  • -Given: 32
  • -Receive: 67
Re: seat belt help
« Reply #9 on: May 02, 2016, 09:26:57 pm »
Yup, the part of the seat that the middle belt is attached to. Fold the seat forwards to slacken the belt before undoing the bolt to avoid any stress on the bolt when it's released but I think you'd be better off just taking the seat out completely to reset it if it's that stuck. Have a look at my video above to see how to the seats remove if youv not already done so
Offline kierhanlon6
Re: seat belt help
« Reply #10 on: May 03, 2016, 10:35:30 pm »
yeah watched the video thanks for your help will def give it a go weekend and let you know how i get on thanks for your help
Offline kierhanlon6
Re: seat belt help
« Reply #11 on: May 06, 2016, 06:21:12 pm »
thanks for all your help the seat belt if finally free. video was very helpful thanks. do you think it will happen again if i put the seats down. can't understand why it happens.
cheers
Offline MateyGuv
  • -Given: 32
  • -Receive: 67
Re: seat belt help
« Reply #12 on: May 06, 2016, 06:33:23 pm »
It's likely to have originally happened when the seat was down and maybe jolted so the lock mechanism engaged or possibly when the seat was put back into its upright position. It's unlikely to happen again in the upright position - the belt is still locking if you pull it hard right? Safety first and all that
If it does happen again you'll know what to do to sort it out  :happy2:
Offline kierhanlon6
Re: seat belt help
« Reply #13 on: May 07, 2016, 11:56:22 am »
yeah its still locking when i pull it hard. when i fold the seats down again I'm going to pull a lot of slack out and put tie a bow in to it so there is plenty of slack if it does seem to lock. thanks again
Offline MateyGuv
  • -Given: 32
  • -Receive: 67
Re: seat belt help
« Reply #14 on: May 07, 2016, 11:57:27 am »
No worries  :happy2: and thank you for the thank you's  :drinking:
