Author Topic: TT RS Setup on Edition 30 - Disc Options  (Read 3925 times)
Offline oak_grun
« on: April 26, 2016, 02:11:52 pm »
Hi,
Will be putting some new discs on shortly and wondered what others are using with their TT RS setup. Input from Edition 30 owners running standard wheels would also be helpful.
So..currently I'm running TT RS 2 piece discs with 12 mm spacers to clear the standard Pescera alloys.
I've read that some use the TTS disc which I think is 345mm and bolts on with adaptor kit from DaveB. Anyone running this setup?
Is the R32 or S3 disc an option also?
Any input from people who are running TT RS calipers would be helpful.
Thanks :happy2:
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=m9lff9k0v533rq23gb9pl35614&/topic,19740.0.html
Re: TT RS Setup on Edition 30 - Disc Options
« Reply #1 on: April 26, 2016, 03:00:38 pm »
You can run either the 340mm or 345mm discs with the different brackets. 340mm are 10kg, 345mm are 12kg so youd be daft not to get the 340mm.
Or you can run 362mm which are 8kg  :laugh:
« Last Edit: April 26, 2016, 03:04:22 pm by rich83 »
Offline oak_grun
« Reply #2 on: April 26, 2016, 04:37:56 pm »
 do the 340mm come off r32/s3  and 345mm discs off the tts?
I guessing 362mm are bespoke jobbies?
Offline 94Luke
« Reply #3 on: April 26, 2016, 04:44:53 pm »
Other way round
« Reply #4 on: April 26, 2016, 04:50:24 pm »
R32/S3 - 345
TTS - 340
362 - AP racing 2 piece
Offline FoleE
« Reply #5 on: April 27, 2016, 12:33:58 am »
I'm running 340mm mtec discs with the vagbrem. adapters. Use 13mm spacers to clear the Pescs.
Offline oak_grun
« Reply #6 on: April 27, 2016, 08:27:33 am »
Do the mtec discs differ from tts discs?
Any pics of ur car running gear the 13mm.spacers?
« Reply #7 on: April 27, 2016, 09:56:40 am »
Mtec are just the brand. @xjay1337 uses Mtec 340mm discs with ttrs calipers
Offline xjay1337
  • -Receive: 377
« Reply #8 on: April 27, 2016, 10:15:39 am »
Yup mtec j hook discs here.....mtec are just a brand.......
Seem better than the EBC USR discs i had before no issues so far and i've given them some hell.
another vote for the tts 340mm discs is that they have fullly vented channels . around the hub of the disc the vents run from there to the open gap on the edge of the disc where as the r32/s3 345mm discs do not have this.
Offline oak_grun
« Reply #9 on: April 27, 2016, 11:18:07 am »
How much are the j hook discs?
Offline KieranM
« Reply #10 on: April 27, 2016, 06:58:26 pm »
Does anyone know if the TTRS calipers and 340 discs will fit under 17s?
Offline AJP
  • -Given: 392
  • -Receive: 316
« Reply #11 on: April 27, 2016, 07:11:03 pm »
Very unlikely. As far as I know the only upgrade that definitely will is the S3/R32 caliper.
Offline FoleE
« Reply #12 on: April 27, 2016, 08:42:04 pm »
Hope that helps. Discs I purchased from here http://www.mtecbrakes.com/brake-discs/audi/tt-roadster-2006/tt-2-5t-fsi-rs-quattro-07-09.html (MTEC1597)
Offline oak_grun
« Reply #13 on: April 27, 2016, 10:07:14 pm »
Looks good. Discs are reasonably priced too. :happy2:
Brackets will be needed next.
