Author Topic: NQSBBK questions  (Read 2455 times)
Offline danc1706
NQSBBK questions
« on: April 26, 2016, 06:28:11 pm »
Looking at buying an nqsbbk for the edition 30! Porsche brembo 4 pots!
What else do I need too make this fit?
Can I use tts 340mm discs? If not which ones?
What's pads would be best?
Gonna be running standard wheels so will I need spacers?
Do I need to change my MC for the brakes?
Sorry for all the questions lol
Cheers in advance
ED30 stage 1.5 330bhp 328ftlb
Offline Paradox1
  • -Given: 41
Re: NQSBBK questions
« Reply #1 on: April 28, 2016, 10:28:42 am »
you need 986 FRONT Calipers
Caliper adapters
You can use yoru standard disks
Braided brake lines
Pads - Pagid, Mintex, DS2500
And may aswell change the brake fluid while you at it
Offline petesimcock
« Reply #2 on: May 21, 2016, 12:05:48 am »
I run 10mm spacers with my NQSBBK as they were the smallest hubcentric spacers I could get, plenty of clearance now, I think 8 would do it.
Also make sure you get a set of anti squeal shims and some proper lube for them otherwise they will probably squeal like anything.
Offline Paradox1
  • -Given: 41
« Reply #3 on: May 23, 2016, 01:11:38 pm »
Go on Pete, show me some pics!
Offline petesimcock
« Reply #4 on: May 29, 2016, 03:13:03 pm »
Ignore my wheels they need binning.
Offline Paradox1
  • -Given: 41
« Reply #5 on: May 29, 2016, 05:48:19 pm »
Looks sweet. Once my brakes need replacing,I'll be going this route
Offline petesimcock
« Reply #6 on: May 29, 2016, 11:33:10 pm »
They are great. A little noisey if you don't keep the pads lubed but other than that no complaints and huuuugely better than stock
