Author Topic: rear brake shield removal  (Read 1914 times)
Offline strongbow
« on: April 29, 2016, 04:02:29 pm »
hi,
my rear brake shield has rusted and started to rattle which is driving me mad. can I remove it without taking off the rear bearing,obviously need to remove disc and carrier with is a bummer. any advise would be great cheers.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Re: rear brake shield removal
« Reply #1 on: April 29, 2016, 04:36:38 pm »
No
Offline jayha11
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,97064.0.html
« Reply #2 on: April 29, 2016, 04:55:30 pm »
Yes you can as I have done this already, I will be doing the NS rear soon too as that is starting to rattle. I used tin snips, in short jack it up, remove the wheel and cut a pizza slice out of it getting as near to the center as you can. It will take a bit of force and bending/manipulating and possible cutting bits off the top/sides but eventually it will give in and come away causing no damage to the caliper/carrier or anything.
Hope this helps
Mk5 GTI > S3 8P > Cupra 300 > Cupra 290 > Mk5 R32
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #3 on: April 29, 2016, 05:30:32 pm »
If you're not replacing it then yes  :signLOL:
Offline Lewo
« Reply #4 on: April 29, 2016, 11:06:20 pm »
Would you want to replace it?
When I asked the other month the opinion was kind of no!
Offline strongbow
« Reply #5 on: April 30, 2016, 01:53:15 pm »
might replace in future,but need to sort noise out now.
cheers jayha will do this sunday.
