Author Topic: Fitted new kenwood unit some reason air bag light come on  (Read 2668 times)
Offline gjseb16
« on: April 30, 2016, 08:17:11 pm »
Right guys just finished fitting new dab kenwood all gone in a treat a part from air bag light come on don't understand. So scan car with just vag com reader an there no faults on car any ideas
Offline doylebros
Offline gjseb16
Re: Fitted new kenwood unit some reason air bag light come on
« Reply #2 on: April 30, 2016, 08:31:24 pm »
Only thing I don't get is didn't do this when I fitted the last one which is what is throwing me out
« Reply #3 on: April 30, 2016, 08:32:45 pm »
If you unplugged the air bag plug in the centre part of the vents and turned on the ignition it will cause a fault,just needs turning of
Offline gjseb16
« Reply #4 on: April 30, 2016, 08:43:44 pm »
Yeah that's exactly what I did balls how come it don't show up as a fault though mate on  a reader
« Reply #5 on: April 30, 2016, 08:46:05 pm »
Has he got vag com or some thing similar to scan it
Offline gjseb16
« Reply #6 on: April 30, 2016, 08:50:56 pm »
Yeah just scanned with my reader mate but I can normal erase my faults but it not listing any mate which I don't understand
Cheers Gordon
Offline Nasir
« Reply #7 on: April 30, 2016, 08:51:39 pm »
Is it a proper VCDS? If the airbag light is on then there has to be a fault code.
Shadow Blue 2007 GTI DSG (Standard)
Offline gjseb16
« Reply #8 on: April 30, 2016, 08:53:05 pm »
No  it not vcds just a cheap reader off net but it says all faults erased but light still on
Cheers Gordon
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #9 on: April 30, 2016, 08:53:14 pm »
If it's a dodgy reader you won't get a code?.
You require an air bag type of reader eg vagcom mate.  where you located?.
« Reply #10 on: April 30, 2016, 08:55:21 pm »
Yeah needs vag com or similar to turn the light of,some where local might do it for you or a decent garage
Offline gjseb16
« Reply #11 on: April 30, 2016, 09:03:07 pm »
I am located in Skegness Lincolnshire back off beyond never any one local to me dealers going to rape me ain't they
« Reply #12 on: April 30, 2016, 09:06:46 pm »
Put a post up and see as you never know
« Reply #13 on: April 30, 2016, 09:09:59 pm »
Have a look here to see if any member is close to you
http://www.mk5golfgti.co.uk/forum/index.php/topic,88875.0.html
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #14 on: April 30, 2016, 09:11:53 pm »
£145 odd rape case FYI if not more.
check the link below  :happy2:
