Author Topic: noise when turning hard right  (Read 4514 times)
Offline Ajthird3
« on: May 02, 2016, 02:04:56 pm »
hi, anyone ever had a problem with a rubbing noise when turning hard to left/right. checked in the wheel arch and there is no sign of rubbing..
Offline th3_f15t
  • -Receive: 183
Re: noise when turning hard right
« Reply #1 on: May 03, 2016, 11:19:36 am »
What sort of noise is it? Clunking, grinding ect..?
Offline Ajthird3
« Reply #2 on: May 04, 2016, 06:46:50 am »
It sounds like a scuffing noise, had a look in the wheel arch and there was no signs of anything being rubbed. Booked in to the local vw today
Offline Paradox1
  • -Given: 41
« Reply #3 on: May 04, 2016, 03:55:21 pm »
Are you lowered?
Could be scrubbing your roll bar
Offline Ajthird3
« Reply #4 on: May 06, 2016, 10:02:51 am »
No just the standard height
Offline th3_f15t
  • -Receive: 183
« Reply #5 on: May 08, 2016, 01:48:24 pm »
Have a look at the inner wheel and arch, plus the suspension and roll bar (as mentioned). May see signs of the cause there...
Offline Ajthird3
« Reply #6 on: May 10, 2016, 09:52:12 pm »
will have a look tomorrow  :happy2:
Offline m3 mick
« Reply #7 on: May 13, 2016, 04:03:05 pm »
Any chance u figured it out I've a similar noise rubbing/grinding sound when I turn right!!! It's not suspension rubbing or wheel arch rub! Standard height car! Was thinking it was the brake dust shield but just looked there and it's not rubbing any where!!
Offline Ajthird3
« Reply #8 on: May 13, 2016, 10:39:57 pm »
Havnt figured it out yet, it sounds like we have something similar. took it to vw and they blamed the aftermarket exhaust which was s*** because it did it before the exhaust. Annoying
Offline m3 mick
« Reply #9 on: May 14, 2016, 05:20:08 pm »
Mine litterally sounds like it's rubbing once the car is turning right at all!!! Had a good luck under it yesterday and theirs rubbing so next guess is brake pad off disk (somehow) or wheel bearing or driveshaft!!
