Author Topic: Euro carparts 25% off this bank hol, need disc brake info so I can order please!  (Read 943 times)
Offline Lewo
Alex said that Brembo are the ones to get so are the prices good for the discs & pads with the 25% off these prices?
Also What size are the discs F & R on a 56 plate GTI?
http://www.eurocarparts.com/brake-disc
http://www.eurocarparts.com/brake-pad
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=3dv84576r7juaotvlt97s4icrv&/topic,19740.0.html
ECP is usless....
Select my car (GTI)
Select brakes
It lists about 4 different sizes....  :fighting: :fighting:
You want 312mm front. 286mm rear
Offline howie1987
  • -Given: 92
  • -Receive: 20
Carpartsforless are the same company. prices are cheaper and if buying brake discs you should be able to use the £15 or £10 off code on they're homepage.
Worth comparing prices anyway.
Offline Lewo
Cheers guys, I'll try CPFL any where else also worth comparing prices.
Or... mtec... they are very reasonable
